CRC errors increasing, but pingtests are 100% ok!
SlevinKelevra
Gents,
My crc errors are steadily increasing on the Ethernet segment, but when i ping the BGP neighbor (so packets travel accross this "bad" segment) i do not see any packets going bad. Anyone got an explanation for this?
How is this possible, i would expect at least something going wrong with my ping test.
Unfortunately Google could not help me.
xxxx#ping xxx.22x.193.174 repeat 1000 size 1400
Sending 1000, 1400-byte ICMP Echos to xxx.22x.193.174, timeout is 2 seconds:
Success rate is 100 percent (1000/1000), round-trip min/avg/max = 232/251/552 ms               <===
xxxx#sh int Fa0/0
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is 001f.9ee5.d32a (bia 001f.9ee5.d32a)
  Description: ISP
  Internet address is xxx.12x.110.226/27
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:18, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:05:28
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 214000 bits/sec, 76 packets/sec
  5 minute output rate 232000 bits/sec, 72 packets/sec
     25999 packets input, 9368996 bytes
     Received 7 broadcasts, 0 runts, 0 giants, 0 throttles
     66 input errors, 66 CRC, 0 frame, 0 overrun, 0 ignored               <===
     0 watchdog
     25199 packets output, 10021048 bytes, 0 underruns
     6 unknown protocol drops
     0 lost carrier, 0 no carrier
18 Replies 18
Rizwan Khan
Are the crc growing still? There is a possibility thay they might be generated before and the cable is good now. Try clearing the interface counters and again ping and check the interface status.
Sent from Cisco Technical Support Android App
I have send out a NEW wic card to the site, we are going to replace it, both sides are configured as 100/full hard coded (auto neg = off) Will keep you posted!
Reasons for CRC error.
1. cable issue( some times cross cable will used instead of Straight cable vice versa).
2: Duplex and Speed mismatch.
After replacing this two still problem persist then might problem with port..
Once replaced cable and Configuration.. Before generating ping clear the counters and observe the errors..
If you have two Cisco devices, I'd recommend you enable auto-negotiation.  When you hard-code the speed and duplex, you'll see more line errors.
