Crestron nvx configuration- Catalyst 3650
Can any help me with the CLI commands to set up Crestron NVX multicast traffic w/ fast leave etc.
The Crestron NVX allows you to setup the multicast address on the device, but what are the commands needed to setup the GB interface ports to allow the multicast Crestron traffic?
balaji.bandi
check below guide : (its all depends requirement what switch need to be done, enable multicast routing, pim and igmp should work)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/37e/multicast/configuration_guide/b_mc_37e_3650_cg/b_mc_3e_3650_cg_chapter_01100.html
BB
This is perfect. Thank you!
if that works and no further queries mark as solution - this will help community if some one looking for the solution.
BB
