CSR1000v and MPLS
antonio.guirado
Level 3
Level 3
i want to try MPLS in a CSR1000v. I am using csr1000v-universalk9.03.16.05.S.155-3.S5-ext.ova on workstation 12.5.5 build-5234757.
The issue is that I have downloaded a trial security license and installed in the VM but MPLS commands are not supported.
Can any one help me?.
Regards.
Router#show version
Cisco IOS XE Software, Version 03.16.05.S - Extended Support Release
Cisco IOS Software, CSR1000V Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 19-Jan-17 09:11 by mcpre
ROM: IOS-XE ROMMON
Router uptime is 22 hours, 35 minutes
Uptime for this control processor is 22 hours, 37 minutes
System returned to ROM by reload
System image file is "bootflash:packages.conf"
Last reload reason: Reload Command
License Level: security
License Type: Permanent
Next reload license Level: security
cisco CSR1000V (VXE) processor (revision VXE) with 2056435K/6147K bytes of memory.
Processor board ID 9E2B62UMAPE
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3988292K bytes of physical memory.
7774207K bytes of virtual hard disk at bootflash:.
Router#show license
Index 1 Feature: advanced
Index 2 Feature: standard
Index 3 Feature: ax
Index 4 Feature: security
Index 5 Feature: lite
Index 6 Feature: vacs
Index 7 Feature: appx
Index 8 Feature: ipbase
Index 9 Feature: prem_10M
Index 10 Feature: prem_50M
Index 11 Feature: prem_100M
Index 12 Feature: prem_250M
Index 13 Feature: prem_500M
Index 14 Feature: prem_500M_8G
Index 15 Feature: prem_1G
Index 16 Feature: prem_1G_16G
Index 17 Feature: prem_2500M
Index 18 Feature: prem_5G
Index 19 Feature: prem_10G
Index 20 Feature: prem_200G
Index 21 Feature: ax_10M
Index 22 Feature: ax_50M
Index 23 Feature: ax_100M
Index 24 Feature: ax_250M
Index 25 Feature: ax_500M
Index 26 Feature: ax_500M_8G
Index 27 Feature: ax_1G
Index 28 Feature: ax_2500M
Index 29 Feature: ax_5G
Index 30 Feature: ax_10G
Index 31 Feature: ax_200G
Index 32 Feature: adv_10M
Index 33 Feature: adv_50M
Index 34 Feature: adv_100M
Index 35 Feature: adv_250M
Index 36 Feature: adv_500M
Index 37 Feature: adv_1G
Index 38 Feature: adv_2500M
Index 39 Feature: adv_5G
Index 40 Feature: adv_10G
Index 41 Feature: sec_10M
Index 42 Feature: sec_50M
Index 43 Feature: sec_100M
Index 44 Feature: sec_250M
Index 45 Feature: sec_500M
Index 46 Feature: sec_1G
Index 47 Feature: sec_2500M
Index 48 Feature: sec_5G
Start Date: N/A, End Date: Jul 14 2017
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Index 49 Feature: sec_10G
Index 50 Feature: appx_10M
Index 51 Feature: appx_50M
Index 52 Feature: appx_100M
Index 53 Feature: appx_250M
Index 54 Feature: appx_500M
Index 55 Feature: appx_1G
Index 56 Feature: appx_2500M
Index 57 Feature: appx_5G
Index 58 Feature: appx_10G
Index 59 Feature: std_10M
Index 60 Feature: std_50M
Index 61 Feature: std_100M
Index 62 Feature: std_250M
Index 63 Feature: std_500M
Index 64 Feature: std_1G
Index 65 Feature: std_2500M
Index 66 Feature: std_5G
Index 67 Feature: std_10G
Index 68 Feature: ipb_10M
Index 69 Feature: ipb_50M
Index 70 Feature: ipb_100M
Index 71 Feature: ipb_250M
Index 72 Feature: ipb_500M
Index 73 Feature: ipb_1G
Index 74 Feature: ipb_2500M
Index 75 Feature: ipb_5G
Index 76 Feature: ipb_10G
Index 77 Feature: hseck9
Index 78 Feature: internal_service
Index 79 Feature: bb_1K
Index 80 Feature: mem_4G
Index 81 Feature: cgn_1M
Index 82 Feature: stingray
You need Appx license for MPLS. See the following table:-
The Cisco CSR 1000v comes in four technology packages or feature sets, which are shown in Table 7.
Table 7.       Cisco CSR 1000v Packaging
Features
Description
IP Base
  Basic networking: BGP, OSPF, EIGRP, Routing Information Protocol (RIP), Intermediate System-to-Intermediate System (IS-IS), IPv6, GRE, VRF-Lite, NTP, QoS, and CLNS
  Multicast: Internet Group Management Protocol (IGMP) and Protocol Independent Multicast (PIM)
  High availability: HSRP, VRRP, and GLBP
  Addressing: 802.1Q VLAN, EVC, NAT, DHCP, and DNS
  Basic security: ACL, AAA, RADIUS, and TACACS+
  Management: Cisco IOS XE CLI, SSH, Flexible NetFlow, SNMP, EEM, and NETCONF
Security
  IPBase Plus
  Advanced security: ZBFW, IPsec VPN, Easy VPN, DMVPN, and FlexVPN
  Box-to-box high-availability for ZBFW and NAT
AppX
  IPBase Plus
  Advanced networking: Layer 2 Tunneling Protocol Version 3 (L2TPv3), BFD, MPLS, VRF, and VXLAN
  Application experience: WCCPv2, AppXNAV, Network-Based Application Recognition Version 2 (NBAR2), AVC, and IP SLA
  Hybrid cloud connectivity: LISP, OTV, VPLS, and EoMPLS
  Subscriber management: PTA, LNS, and ISG
AX
  All features
For more detail follow the following link:-
http://www.cisco.com/c/en/us/products/collateral/routers/cloud-services-router-1000v-series/datasheet-c78-733443.html
Spooster IT Services Team
Features
Description
IP Base
Security
  IPBase Plus
AppX
  IPBase Plus
AX
  All features
