DDR only for ISDN?
jalexander41
Is DDR only used for ISDN connections? I have a router that I believe formerly had an ISDN connection on it. Now, it only has Frame-Relay. But, there is a dialer-list 1 protocol ip permit & dialer-list 1 protocol ipx permit statement on the router. Is this a "leftover" or is it still being used?
Yes, you can remove them.
Dialer list commands are mostly used over Dial on-demand links like the ISDN.
Check where the dialer-group command is applied.
You are the best person who knows your setup and we cant say if it is a "leftover" or still being used.
More info on DDR:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/dial_r/drprt3/drhowddr.htm
There is no dialer-group command on this router. I inherited this router & it's configs.
Here is the config - some stuff was changed to protect the innocent!
Current configuration:
version 11.3
hostname Router1
boot system flash 1:80273404.bin
enable secret XXX.
interface Ethernet0/0
ip address 172.16.18.1 255.255.255.0
ip helper-address 172.16.108.23
interface Serial0/0
ip address 172.16.42.2 255.255.255.0
encapsulation frame-relay IETF
frame-relay interface-dlci 291
router rip
network 172.16.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.42.1
snmp-server community public RO
snmp-server location XXX
snmp-server contact XXX
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password XXX
login
end
