OSPF summary-address
davegibelli
Why does the following not work?
router ospf 1
redistribute connected
summary-address 0.0.0.0 0.0.0.0
I expect OSPF to distribute a default route but instead OSPF stops announcing any routes!
Any ideas?
7 Replies 7
Harold Ritter
The only mean to inject the default route in an OSPF autonomous system is through the use of the command "default-information" originate.
Hope this helps,
Dave,
The 'summary-address' command is used in ASBR, router connecting to an external AS, and I am guessing this router may be connected to your ISP.
If that's the case then just like Harold stated configure 'default-information originate' under your OSPF process and the router would continue to inject a default route as long as it has a default route in it's routing table.
Sundar
Sundar
With bgp you will not get a default route from a peer so there is no default route in your routing table in the first place.
I want to summarise all bgp routes into a default route and only inject this default into ospf if the bgp session is up...
How would I make a default injection conditional?
Can you elaborate what you are trying to do?
Sundar
I have two bgp routers, each has a single peering session. I want each bgp router to annouce a default route into ospf but only if the bgp session is up.
Sounds simple but I cannot figure out how!
Have a look at the last example in this link titled 'conditional default origination'.
http://cisco.com/en/US/products/sw/iosswrel/ps1826/products_configuration_guide_chapter09186a00800877d7.html
Sundar
