default-information originate
mohammedmahmoud
Level 11
Level 11
Hi All,
I understand that for a routing protocols to advertise a default route to its neighbors using the "default-information originate" command, ISIS, EIGRP, OSPF (unless using the always keyword) and BGP (requiring further redistribution) needs a default route to already exist in the routing table before advertising a default route through that command, can any one confirm whether RIP requires valid default route in the routing table before originating the default route using this command or not ?
Thanks in advance,
Mohammed Mahmoud.
Harold Ritter
When used with RIP, the "default-information originate" will generate the default route whether it is present in the RIB or not.
You need to use a route-map if you wish to conditionally generate the default route.
Hope this helps,
Hi Harold,
Thanks alot, what about IGRP and EIGRP ?
Mohammed,
EIGRP does not provide conditional advertisement features such as RIP, OSPF or BGP. EIGRP does not advertise its default route by using default information originate.
With EIGRP you need to create a default route or an interface summary route, for instance
router eigrp 10
redistribute static
ip route 0.0.0.0 0.0.0.0 null0
or
interface s0/0
ip summary-address eigrp 10 0.0.0.0 0.0.0.0
HTH,
Hey there,
I've confirmed what you've said but with only one thing to add; Normally, exterior/default routes are always accepted and default information is passed between EIGRP processes when redistribution occurs. when doing so, we still need to confirm the following command to either allow the sending or receiving of a default route (should be there by default):
Router(config-router)#default-information ?
allowed Allow default information
in Accept default routing information
out Output default routing information
Note: The default network of 0.0.0.0 used by Routing Information Protocol (RIP) cannot be redistributed by IGRP but can be redistributed by EIGRP.
Thanks very much.
