C3550 QOS Configuration
nuetel111
I have configurations from 3750 switch that do not work in Catalyst Switch 3550. Could anyone help me change these configurations for 3550 Switch
stack-mac persistent timer
mls qos srr-queue output cos-map queue 1 threshold 2 5 6
mls qos srr-queue output cos-map queue 2 threshold 2 0
mls qos srr-queue output cos-map queue 3 threshold 1 1
mls qos srr-queue output cos-map queue 3 threshold 2 2
mls qos srr-queue output cos-map queue 4 threshold 1 3
mls qos srr-queue output cos-map queue 4 threshold 2 4 7
mls qos queue-set output 1 threshold 1 50 100 100 100
mls qos queue-set output 1 buffers 27 13 20 40
interface range fa0/1 - 24
srr-queue bandwidth share 27 13 20 40
royalblues
Level 10
Level 10
Hi Friend,
AFAIK SRR (shaped round robin) is not supported on the 3550.
Heres a link for configuring QoS on the 3550
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12225se/3550scg/swqos.htm
HTH, rate if it does
Narayan
Could you please assist me in how to configure the QoS for 3550 for same pattern of output
