Defective Console Port of 2620 Router
haucisco
Hi, I have this specific concern regarding our 2620 router.
When I establish a console connection with it and use the default setting for COM1 properties, I can see the usual messages from bootup process until it show the question "Would you like to enter the initial configuration dialog (y/n)?".
It seems that it runs normally, but when I try to use my keyboard to input any characters, it doesn't respond. I try to restart the router and use ctrl-break but still no response from the router.
Do you have an idea or prior experience regarding these? I would be much oblige for the help.
6 Replies 6
spremkumar
Level 9
Level 9
hi
Once you get pass the initial configuration prompt can you try changing the console settings from default to some other option and see ?
I had faced this problem quite sometime back with 800 series router and got it worked in the above fashion..
regds
hi spremkumar, thank you for your suggestion. I have tried it, unfortunately it also doesn't work.
Do you have any other idea? Thanks in advance.
desai.jaideep
Level 5
Level 5
Have u tried changing console cable and the PC?Try above inspite of other router's working on same setup.
JD
Hi JD,
I tried different combinations of PC and console cables but none of them are successful.
Do you have other suggestion?
Pal
Did you try to use VT100 or ANSI terminal type ? Did you try other terminal program ?
If you tried different combination, I suspect the console is failure.
hi jackyoung,
Yes sir I have tried VT100 terminal emulation software but none of them works.
So it seems that the Console Port fails, can you suggest how can I use the AUX port and proper setup?
Thank you sir in advance.
Pal
