Destination Nat from Cisco Is 1900 router to firewall
catrinamalang
Hi all,
we have configured dynamic vpn in a firewall which is behind a Cisco firewall.
But remote clients are unable to connect to vpn configured in the firewall which is
behind the router where isp link terminates.
Any help on how we can configure a path from isp interface in the router pointing to firewall interface? Can Destination/source nat work here? If so how can we configure it
Thanks.
Thing
balaji.bandi
Can you able to provider Cisco 1900 router configuration to review.
Make sure you have right NAT in place for port 500/4500
BB
Please elaborate on how this NAT can be setup for port 500/4500
In addition to @balaji.bandi @comments would you post a diagram of your current network topology please
Kind Regards
Paul
Deepak Kumar
Use the below configuration but for more information, we required your network details as a network diagram, etc.
  • ip nat inside source static udp inside_ip 4500 interface interface 4500
  • ip nat inside source static udp inside_ip 500 interface interface 500
Inside_ip = IP address of the firewall
interface= WAN interface of the router.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
