Determine Serial Line Speed
Aaron Harrison
Does anyone know a good command to determine the clock speed on a serial circuit?
Show controllers sometimes gives it, but on some routers it doesn't....
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Richard Burts
Aaron
The only way I know to get the clock speed is the show controller serial command. And as you point out sometimes the clock speed is given and sometimes it is not.
Rick
Rick
zaqtivi
on the router itself, i just use 'sh run' .. that's the only way i know how to determine clock speed hehe
DEar Zaqvi,
The clock speed u can find by running show controller serial command .This command gives output as REceived Clockrate .
but this command gives output i.e. Received Clockrate only from 7200 series onwards .
If we run same command on 3700/1800/2800, we do not get output as Received Clockrate.
regds,
Aman
