Device MAC Address for a 2911
Jelani_DTE_PRO
Which command should I use, to learn the device MAC address for a 2911? I'm configuring Port Forwarding, for access to my lab equipment. And, in haste last night, I executed a "show version" on my 2911s, thinking I would find their respective MAC address within a saved text file. Of course, when I later looked over the files that contain the "show version" info, it's not there. I did find a MAC address of each 2911, after executing a "show arp" on one of my switches. However, that seems to be the interface MAC address...because Port Forwarding, isn't allowing me access to those devices.
And, yes, I was able to access those 2911s with a direct connection to my ISP router...using the protocol I've configured for Port Forwarding.
Each interface will have a MAC address. There is no device MAC address. Whichever interface you are connected to is the MAC address you are sending packets to and from.
7 Replies 7
ctbower98
Router#show interface fa0/0
FastEthernet0/0 is administratively down, line protocol is down
  Hardware is CN Gigabit Ethernet, address is 4c00.8262.3c99 (bia 4c00.8262.3c99)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Hi. And, thanks for the reply.
However, that looks to be the MAC address for that interface.... I would like to know how to obtain the device MAC Address...
ctb,
I was hoping no one would say that...there's no device MAC address, unlike in the case of a base Ethernet address for a switch. Now, I have to wait 'til this evening to further troubleshoot and get this resolved. UGH! LOL!
Thanks, for your feedback.
Just to add a note to what ctbower98 noted, if you use a virtual IP, like HSRP, it will have a virtual MAC.
Hi, Joseph.
Isn't that the same (interface) MAC address that can be found, within a "show arp"?
Yes, it might be seen there.
BTW, if you're looking for a "device MAC", something like a HSRP MAC might suffice as I recall (?) you can use the same HSRP group on different interfaces (i.e. each interface might then have the same virtual MAC.
Also, there might be a command to assign a MAC to a physical interface. If so, you could have different interfaces with the same MAC.
