Device rebooted
Eng.AD27
Dears
my  cisco  ASR920  restarted many times and the reload reason below
Last reload reason: Critical software exception, check bootflash:crashinfo_RP_00_00_20220708-203242-BGH
any know whats this  issue .. and will be thankful
6 Replies 6
Leo Laohoo
Post the complete output to the following commands:
sh version
dir
sh log on uptime
Eng.AD27
router#sh version
Cisco IOS XE Software, Version 16.09.01a
Cisco IOS Software [Fuji], ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 16.9.1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Thu 26-Jul-18 18:08 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
router uptime is 18 minutes
Uptime for this control processor is 22 minutes
System returned to ROM by reload at 15:35:41 BGH Mon May 23 2022
System restarted at 12:00:32 BGH Sun Jul 24 2022
System image file is "bootflash:asr920igp-universalk9_npe.16.09.01a.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: metroipaccess
License Type: Permanent
Next reload license Level: metroipaccess
cisco ASR-920-12SZ-A (Freescale T1042) processor (revision 1.2 GHz) with 896057K/6147K bytes of memory.
Processor board ID CAT2247U09G
12 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3670016K bytes of physical memory.
3089999K bytes of eMMC flash at bootflash:.
router# dir bootflash:
Directory of bootflash:/
11 drwx 16384 Nov 28 2018 22:00:35 +03:00 lost+found
112673 drwx 4096 Jul 8 2022 20:43:25 +03:00 .prst_sync
12 -rw- 452027261 Nov 28 2018 22:12:35 +03:00 asr920igp-universalk9_npe.16.09.01a.SPA.bin
104625 drwx 4096 Dec 13 2018 07:34:42 +03:00 .installer
72433 drwx 4096 Jul 8 2022 20:35:29 +03:00 core
144865 drwx 4096 Nov 28 2018 22:25:52 +03:00 onep
96577 drwx 16384 Jul 24 2022 12:15:58 +03:00 tracelogs
13 -rw- 1165 Nov 28 2018 22:15:33 +03:00 CAT2247U09G_2_1543461328.lic
14 -rw- 1184 Nov 28 2018 22:16:10 +03:00 CAT2247U09G_2_1543461365.lic
32193 drwx 4096 Nov 28 2018 22:22:38 +03:00 .rollback_timer
136817 drwx 4096 Jun 26 2019 13:37:10 +03:00 .dbpersist
15 -rw- 471215538 Jul 24 2019 12:57:05 +03:00 asr920igp-universalk9_npe.16.11.01c.SPA.bin
128769 drwx 4096 May 23 2022 15:46:33 +03:00 license_evlog
56337 drwx 4096 Aug 20 2019 16:44:11 +03:00 dualrate_config
16 -rw- 35 May 23 2022 15:46:48 +03:00 pnp-tech-time
17 -rw- 64991 May 23 2022 15:46:52 +03:00 pnp-tech-discovery-summary
18 -rw- 485989308 May 23 2022 16:20:51 +03:00 asr920igp-universalk9_npe.16.12.05a.SPA.bin
19 -rw- 27542 Jul 8 2022 20:29:59 +03:00 puntinject_stats.log.0
20 -rw- 27543 Jul 8 2022 20:32:02 +03:00 puntinject_stats.log.1657301392
21 -rw- 285817 Jul 8 2022 20:32:49 +03:00 crashinfo_RP_00_00_20220708-203242-BGH
3114463232 bytes total (1055649792 bytes free)
router# sh log on uptime
Slot Reset reason Power On
0 ZTP reset 11/27/18 05:52:22
0 reset power on 11/27/18 21:01:37
0 reset board from RP 11/28/18 21:43:07
0 reset power on 11/28/18 22:22:17
0 reset power on 11/28/18 22:38:01
0 reset power on 06/26/19 11:50:33
0 reset power on 06/27/19 01:23:17
0 reset power on 06/27/19 03:35:17
0 reset power on 06/28/19 06:47:17
0 reset board from RP 07/24/19 13:04:36
0 reset power on 07/24/19 13:15:26
0 reset board from RP 08/20/19 17:00:06
0 reset power on 12/27/19 20:31:30
0 reset board from RP 01/08/20 05:48:25
0 reset power on 01/11/20 04:10:42
0 reset power on 01/11/20 07:43:20
0 reset power on 04/25/21 06:24:52
0 reset power on 05/23/22 15:26:39
0 reset board from RP 05/23/22 15:40:47
0 reset power on 05/24/22 14:06:10
0 reset power on 06/06/22 14:28:29
0 reset power on 06/15/22 17:43:17
0 cpu hard reset 07/08/22 16:40:04
0 reset board from RP 07/08/22 20:40:05
0 reset power on 07/24/22 11:57:38
The outage on 08 July 2022 was due to a crash.  The evidence is due to the presence of the crashinfo file as well as the output from command "sh log on uptime" which states:
The latest outage happened on at 1157 BGH, 24 July 2022 and the output from the "sh logs" and "sh log on uptime" both confirms a power outage:
May I offer an advice?
  1. Stop using 16.9.1a and upgrade to the latest 16.9.X release.
  2. Do NOT use 16.10.X (and later).
  3. Do NOT use 17.X.X.
  4. After upgrading to the latest 16.9.X, read FN - 72323 - Cisco IOS XE Software: QuoVadis Root CA 2 Decommission Might Affect Smart Licensing, Smart Call Home, and Other Functionality.  Do not ignore this FN or the router will crash due to memory leak.  Make sure to action the workaround only.
Dear
thank you
so  how can  i  solve  this  crashinfo ?
Mark Elsen
  - Connect to the ASR920 with : https://cway.cisco.com/cli .at the top right Press or Run 'Crashdump Analyzer' ;  you may also use the latest advisory release if applicable : https://software.cisco.com/download/home/286037604/type/282046477/release/Gibraltar-16.11.1a
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
