Which Router to Buy for Cisco Network Academy?
sadams0979
I'm helping my netacad instructor out by picking out some models of routers and switches. We currently have ISR 1941 routers. We are looking to purchase about 30-35 switches and routers. Our requirements for the router is that it run IOS-XE and I was looking at either the ISR 4221 OR ISR 1111 Series. What is the main difference besides voice and expansion slots? Would we be able to get our own sales rep for the order, or is it usually for larger orders?
whether you need the ISR111x or the 4221, or any other model, obviously depends on the size of your network, what kind of uplink (WAN) capacity and throughput you want, and if you actually do, or do not, need the expansion modules. The 4221 is about twice the price of the ISR111x, so that is probably a consideration as well.
balaji.bandi
Since this is not a production environment, for Lab requirement mainly to practice technology and commands, so if your investment will be protected always. It looks like you investing a decent amount of money, so contact local SE or cisco partner, so he will be able to suggest to right bill of material so there are no surprises later.
ISR 4K and ISr 1K both does the work, only difference where we need to use in the production environment for the speed and performance matter.
BB
Mark Elsen
 https://www.cisco.com/c/en/us/products/routers/router-selector.html
 M.
Ashor
please I need help
We are trying to make a Cisco Net Academy in our region, and I do not know what the full procedures are for that and what I should prepare, knowing that the place is in several universities to make laboratories and are ready to equip them, not for profit.
please can any one tell me what should I do ?
