DHCP configuration on Cisco Router
kkonuru123
Hi All,
I have a cisco router and access point and two PC's.  Access Point is connected to the router. ISP is connected to the Router.
I have tried the configuration in packet tracer but systems are not getting IP address from access point. Something is wrong, could you help me.
Connected as Router Fa(0/0/0) to AP (Port0) to PC. Below is the configuration.
hostname Router
ip dhcp pool pool1
 network 10.10.1.0 255.255.255.0
 default-router 10.10.1.1
 dns-server 4.2.2.2
spanning-tree mode pvst
interface GigabitEthernet0/0
 ip address 13.12.11.10 255.255.255.240
 duplex auto
 speed auto
interface FastEthernet0/0/0
 switchport mode trunk
 switchport trunk allowed vlan3
interface Vlan3
 ip address 10.10.1.0 255.255.255.0
5 Replies 5
rizwanr74
Level 7
Level 7
Hello there,
Please change this IP 10.10.1.0 to this: 10.10.1.1 on SVI for vlan3
interface Vlan3
 ip address 10.10.1.1 255.255.255.0
Let me know, if this helps.
Rizwan Rafeek
Hi Rizwan....I tried it but didn't work.
The DHCP configuration is not working for wireless but when I have connected the router to switch and switch to computer, I am getting dhcp ip on computer. But it is not working via access point to system.
Hi Krishna,
It is a configuration problem with wireless device itself but at least your DHCP is working fine.
Your wireless device is a Cisco Access Point or a SOHO router with wifi capability?
Hi Krishna,
you have problem with config on router. It does't work because you make port trunk on router but your access point does't support trunking. when you connect through switch it works becasue you make trunk on swithch and switch supports trunking. Please modify it on router.
 switchport access vlan 3
 switchport mode access
Kazim
