DHCP is not working in Cisco 876 Router
vineethelr
DHCP is not working in my Cisco 867 router, no systems getting IP address. DHCP configuration is given below,
ip dhcp pool LAN-POOL
network 10.x.x.0 255.255.255.0
default-router 10.x.x.2
domain-name xyz.net
dns-server 10.x.x.x
17 Replies 17
I make double check for your ACL it right the DHCP allow to pass.
what IP did you put manually, what is the IP you getting from DHCP ?
you do not need to hide the IP address, its after all private IP address (no one can hack it) so post show run removing password and any sensitive information.
BB
One Idea here,
I thing since there are two pool in router the router assign wrong IP to host
this with PACL make connection failed.
how we check that ?
when host get IP from DHCP local Pool
check router via
show ip dhcp pool
see which pool the router use to assign IP to host.
waiting your reply
