DHCP issue with same vlan with different subnets in different location
BobCA
Good morning community!
We are migrating our offices to standard VLAN (2000-2009), 2000 is the management vlan where switches/APs etc have their IPs. It was going well until yesterday when we migrated one office (CKE) that has the same hop as SES (a previously migrated office that was working fine before yesterday)
They all use the same DHCP Server that has different pools for each office and is behind the ICT RTR in a data centre.
We migrated SES last week, everything went well. Yesterday after migrating CKE to standard VLANs, APs in both CKE and SES start having IPs in the other school DHCP pool (Some CKE APs receiving SES Infrastructure IPs 10.65.200 and SES APs receiving CKE Ips on 10.65.10.). So they can’t forward traffic properly.
CKE RTR has an interface on FHC VLAN 2101 and SES RTR has an interface on FHC VLAN 2100.
We think that the DHCP server or a router (FHC or ICT) is being confused about receiving traffic from VLAN 2000 sometimes on 10.65.10 and sometimes on 10.65.200 and thus the lease ends up in the wrong pool.
Upon doing some research, we think we have to set up a layer 3 link between those routers. Would that be a good solution? One issue might be that the next device in line between the FHC RTR and the offices is a layer 2 2960X stack that doesn’t do routing.
CKE RTR CONFIG (edited to remove useless information);
[Also, since the duplicated 2000 vlan was causing issue, we switch it to 1999]
CKE-RTR#sh run br
Building configuration...
Current configuration : 15405 bytes
! Last configuration change at 20:49:11 PST Tue Nov 1 2022 by itss
hostname CKE-RTR
aaa session-id common
boot system switch all cat9k_lite_iosxe.17.03.01.SPA.bin
clock timezone PST -7 0
switch 1 provision c9200-48p
vtp mode transparent
ip routing
ip name-server 10.71.251.8 10.71.251.24
ip domain list yesnet.yk.ca
ip domain name yesnet.yk.ca
vlan 1999
name temp
vlan 2000
name Yesnet_Infrastructure
vlan 2001
name Yesnet_Wired
vlan 2002
name Yesnet_Wireless
vlan 2003
name Tc_Wireless
vlan 2004
name St_Wireless
vlan 2005
name Guest_Wireless
vlan 2006
name IOT
vlan 2007
name VOIP_&_BPI
vlan 2008
name SPARE
vlan 2009
name SPARE2
vlan 2100
name FHC
vlan 2101
name FHC2
vlan 2271
interface Port-channel1
switchport mode trunk
interface Port-channel2
interface Port-channel3
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
shutdown
negotiation auto
interface GigabitEthernet1/0/1
description link to CKE-DHCP1
switchport access vlan 2271
channel-group 1 mode desirable
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
switchport mode access
channel-group 2 mode active
spanning-tree portfast
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/36
description Access Points
switchport trunk native vlan 1999
switchport trunk allowed vlan 1999,2002-2005
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
description CKE-Room127-AP
interface GigabitEthernet1/0/44
description CKE-Room126-AP
interface GigabitEthernet1/0/45
description CKE-Room128-AP
interface GigabitEthernet1/0/46
description CKE-Room123-AP
interface GigabitEthernet1/0/47
description Uplink to Backbone
channel-group 1 mode desirable non-silent
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
no ip address
shutdown
interface Vlan200
no ip address
interface Vlan1999
ip address 10.65.10.254 255.255.255.0
ip helper-address 10.71.250.3
interface Vlan2000
description CKE Infrastructure
no ip address
interface Vlan2001
description CKE Wired DHCP
ip address 10.65.11.254 255.255.255.0
interface Vlan2002
description CKE Yesnet Wireless
ip address 10.65.13.254 255.255.254.0
interface Vlan2003
description CKE tc Wireless
ip address 10.65.14.254 255.255.255.0
interface Vlan2004
description CKE st Wireless
ip address 10.65.15.254 255.255.255.0
interface Vlan2005
description CKE Guest Wireless
ip address 10.65.16.254 255.255.255.0
interface Vlan2006
description CKE IOT
ip address 10.65.17.254 255.255.255.0
interface Vlan2007
description CKE VOIP_BPI
ip address 10.65.18.254 255.255.255.0
interface Vlan2008
description CKE Reserved
ip address 10.65.19.254 255.255.255.0
interface Vlan2009
ip address 10.65.20.254 255.255.255.0
interface Vlan2101
ip address 10.64.101.252 255.255.255.0
router ospf 841
network 10.64.100.0 0.0.0.255 area 0.0.0.0
network 10.64.101.0 0.0.0.255 area 0.0.0.0
network 10.65.10.0 0.0.0.255 area 0.0.0.0
network 10.65.11.0 0.0.0.255 area 0.0.0.0
network 10.65.12.0 0.0.1.255 area 0.0.0.0
network 10.65.14.0 0.0.0.255 area 0.0.0.0
network 10.65.15.0 0.0.0.255 area 0.0.0.0
network 10.65.16.0 0.0.0.255 area 0.0.0.0
network 10.65.17.0 0.0.0.255 area 0.0.0.0
network 10.65.18.0 0.0.0.255 area 0.0.0.0
network 10.65.19.0 0.0.0.255 area 0.0.0.0
network 10.65.20.0 0.0.0.255 area 0.0.0.0
network 10.70.254.0 0.0.0.255 area 0.0.0.0
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.70.254.254
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
ip ssh client algorithm encryption aes128-cbc aes128-ctr aes192-cbc aes192-ctr aes256-cbc aes256-ctr
end
balaji.bandi
The diagram you provided now, it was like before :
we also need to see your switch config.
where is DHCP Server located 10.71.250.3
You have routing as below : ( also you have OSPF configured) - so which one working ?
i do not believe you can reach 10.70.254.254 - because you have FHC router in the path.
so we need to get ICT RTR, FHC RTR, 2960X, SES RTR config to guide as expected.
BB
Hi Balaji,
thanks for your quick reply.
1. DHCP Server is located behind ICT RTR
2. All the offices RTR can reach 10.70.254.254 and internet from any of the VLANs
3. Here are the FHC, 2960X and SES RTR config. I do not have access to the ICT one as we don't manage it and from what I understand, it is just allowing all traffic from this side of the network.
FHC RTR Config edited;
FHC-Backbone-3650#sh run br
hostname FHC-Backbone-3650
ip routing
vlan 2000
vlan 2001
 name Yesnet_Wired
vlan 2002
vlan 2003
 name tc_Wireless
vlan 2004
 name st_Wireless
vlan 2005
 name Guest_Wireless
vlan 2006
 name IOT
vlan 2007
 name VOIP_&_BPI
vlan 2008
 name SPARE
vlan 2009
 name SPARE2
vlan 2100
 name FHC_Infrastructure
vlan 2101
 name Main_LAN_DHCP1
vlan 2102-2103
vlan 2104
 name Secondary_LAN_DHCP1
vlan 2105-2106
vlan 2107
 name Tertiary_LAN_DHCP1
vlan 2108-2129
vlan 2270
 name CKE_Infrastructure
vlan 2271
 name CKE_Reserved
vlan 2272
 name CKE_Wired_DHCP
vlan 2273
 name CKE_Wired_DHCP_3
vlan 2274
 name CKE-YESNET_WiFi
vlan 2275
 name CKE_Wi-Fi_1
vlan 2276
 name CKE_Reserved_2
vlan 2277
 name CKE_Reserved_3
vlan 2278
vlan 2279
 name CKE_Teacher_Wi-Fi_1
vlan 2280
 name CKE_Teacher_Wi-Fi_2/1-1
vlan 2282
 name CKE_Students_Wi-Fi_1
vlan 2283
 name CKE_Students_Wi-Fi_2
vlan 2480
 name SES_Infrastructure
vlan 2481
 name SES_Reserved1
vlan 2482
 name SES_Wired_DHCP_1
vlan 2483
 name SES_Wired_DHCP_2
vlan 2484
 name SES_Wi-Fi
vlan 2486
 name SES_Reserved2
vlan 2487
 name SES_Reserved3
vlan 2488
 name SES_tc_Wi-Fi
vlan 2489
 name SES_One-2-One_Wi-Fi
vlan 2490
 name SES_st_Wi-Fi
vlan 2491
 ip address 1.1.1.1 255.255.255.0
 negotiation auto
interface GigabitEthernet1/0/23
 description Link to VoIP switch.
interface GigabitEthernet1/0/24
 description Temp Mac mini DHCP server
 description Uplink to MAB
 spanning-tree bpdufilter enable
 description link to MLAN-Stack
interface Vlan1
 no ip address
interface Vlan10
 no ip address
interface Vlan106
 description YESNet_InterLink
 ip address 10.70.254.1 255.255.255.0
interface Vlan810
 description Riverdale_Building_Management
 no ip address
interface Vlan2008
 ip address 10.65.238.254 255.255.255.0
interface Vlan2100
 description FHC_Infrastructure
 ip address 10.64.100.254 255.255.255.0
interface Vlan2101
 description FHC_MainLAN-DHCP
 ip address 10.64.101.254 255.255.255.0
 mdns-sd gateway
  service-policy FHC_mDNS
interface Vlan2102
 description Reserved
 ip address 10.64.102.254 255.255.255.0
interface Vlan2103
 description TPC_DHCP
 ip address 10.64.103.254 255.255.255.0
interface Vlan2104
 description FHC-SecondaryLAN-DHCP1
 ip address 10.64.104.254 255.255.255.0
 mdns-sd gateway
interface Vlan2127
 description FHC-AVsystem&AppleTV
 ip address 10.64.127.254 255.255.255.0
interface Vlan2128
 description VoIP Phone system
 ip address 10.191.0.254 255.255.255.0
 ip helper-address 10.71.250.4
interface Vlan2129
 description Comference - Reserved
 ip address 10.64.129.254 255.255.255.0
interface Vlan2499
 description SES_Reserved8
 ip address 10.65.239.254 255.255.255.0
router ospf 841
 network 10.64.10.0 0.0.0.255 area 0.0.0.0
 network 10.64.11.0 0.0.0.255 area 0.0.0.0
 network 10.64.12.0 0.0.0.255 area 0.0.0.0
 network 10.64.13.0 0.0.0.255 area 0.0.0.0
 network 10.64.14.0 0.0.1.255 area 0.0.0.0
 network 10.64.16.0 0.0.0.255 area 0.0.0.0
 network 10.64.17.0 0.0.0.255 area 0.0.0.0
 network 10.64.18.0 0.0.1.255 area 0.0.0.0
 network 10.64.20.0 0.0.3.255 area 0.0.0.0
 network 10.64.24.0 0.0.0.255 area 0.0.0.0
 network 10.64.25.0 0.0.0.255 area 0.0.0.0
 network 10.64.26.0 0.0.0.255 area 0.0.0.0
 network 10.64.27.0 0.0.0.255 area 0.0.0.0
 network 10.64.28.0 0.0.0.255 area 0.0.0.0
 network 10.64.29.0 0.0.0.255 area 0.0.0.0
 network 10.64.102.0 0.0.0.255 area 0.0.0.0
 network 10.64.103.0 0.0.0.255 area 0.0.0.0
 network 10.64.104.0 0.0.0.255 area 0.0.0.0
 network 10.64.105.0 0.0.0.255 area 0.0.0.0
 network 10.64.106.0 0.0.0.255 area 0.0.0.0
 network 10.64.107.0 0.0.0.255 area 0.0.0.0
 network 10.64.108.0 0.0.0.255 area 0.0.0.0
 network 10.64.109.0 0.0.0.255 area 0.0.0.0
 network 10.64.110.0 0.0.1.255 area 0.0.0.0
 network 10.64.112.0 0.0.7.255 area 0.0.0.0
 network 10.64.120.0 0.0.3.255 area 0.0.0.0
 network 10.64.124.0 0.0.0.255 area 0.0.0.0
 network 10.64.125.0 0.0.0.255 area 0.0.0.0
 network 10.64.126.0 0.0.0.255 area 0.0.0.0
 network 10.64.127.0 0.0.0.255 area 0.0.0.0
 network 10.64.129.0 0.0.0.255 area 0.0.0.0
 network 10.65.20.0 0.0.3.255 area 0.0.0.0
 network 10.65.221.0 0.0.0.255 area 0.0.0.0
 network 10.65.222.0 0.0.0.255 area 0.0.0.0
 network 10.65.223.0 0.0.0.255 area 0.0.0.0
 network 10.65.224.0 0.0.1.255 area 0.0.0.0
 network 10.65.226.0 0.0.0.255 area 0.0.0.0
 network 10.65.227.0 0.0.0.255 area 0.0.0.0
 network 10.65.228.0 0.0.0.255 area 0.0.0.0
 network 10.65.229.0 0.0.0.255 area 0.0.0.0
 network 10.65.230.0 0.0.0.255 area 0.0.0.0
 network 10.65.231.0 0.0.0.255 area 0.0.0.0
 network 10.65.232.0 0.0.3.255 area 0.0.0.0
 network 10.65.236.0 0.0.0.255 area 0.0.0.0
 network 10.65.237.0 0.0.0.255 area 0.0.0.0
 network 10.65.238.0 0.0.0.255 area 0.0.0.0
 network 10.65.239.0 0.0.0.255 area 0.0.0.0
 network 10.191.0.0 0.0.0.255 area 0.0.0.0
 network 172.16.27.0 0.0.0.255 area 0.0.0.0
 neighbor 10.70.254.254
no ip http server
ntp server 172.16.1.246
end
SES RTR (edited)
SES-RTR#sh run br
hostname SES-RTR
ip routing
vlan 2000
vlan 2001
 name Yesnet_Wired
vlan 2002
vlan 2003
 name tc_Wireless
vlan 2004
 name st_Wireless
vlan 2005
 name Guest_Wireless
vlan 2006
 name IOT
vlan 2007
 name VOIP_&_BPI
vlan 2008
 name SPARE
vlan 2009
 name SPARE2
vlan 2100,2480-2496
 description Uplink FHC
 no ip address
 shutdown
 negotiation auto
 description Access_Points
 switchport trunk native vlan 2000
 switchport trunk allowed vlan 2000,2002-2005
 switchport trunk native vlan 2480
interface Vlan1
 no ip address
interface Vlan2000
 description SES Infrastructure
 ip address 10.65.220.254 255.255.255.0
interface Vlan2001
 description SES Wired DHCP
 ip address 172.16.27.254 255.255.255.0 secondary
 ip address 10.65.221.254 255.255.255.0
 mdns-sd gateway
  service-policy SES_mDNS
interface Vlan2002
 description SES Yesnet Wireless
 ip address 10.65.223.254 255.255.254.0
 mdns-sd gateway
interface Vlan2003
 description SES tc Wireless
 ip address 10.65.224.254 255.255.255.0
 mdns-sd gateway
interface Vlan2004
 description SES st Wireless
 ip address 10.65.225.254 255.255.255.0
 mdns-sd gateway
interface Vlan2005
 description SES Guest Wireless
 ip address 10.65.226.245 255.255.255.0
interface Vlan2006
 description SES IOT
 ip address 10.65.227.254 255.255.255.0
interface Vlan2007
 description SES VOIP_BPI
 ip address 10.65.228.254 255.255.255.0
interface Vlan2008
 description SES Reserved
 ip address 10.65.229.254 255.255.255.0
interface Vlan2009
 ip address 10.65.230.254 255.255.255.0
interface Vlan2100
 ip address 10.64.100.209 255.255.255.0
interface Vlan2480
 description management
 no ip address
router ospf 841
 network 10.65.220.0 0.0.0.255 area 0.0.0.0
 network 10.65.222.0 0.0.1.255 area 0.0.0.0
 network 10.65.224.0 0.0.0.255 area 0.0.0.0
 network 10.65.225.0 0.0.0.255 area 0.0.0.0
 neighbor 10.64.100.254
ip http server
ip route 0.0.0.0 0.0.0.0 10.64.100.254
end
2960X Config (edited)
fhc-m-stack-1#sh run br
hostname fhc-m-stack-1
no ip domain-lookup
ip domain-name yesnet.yk.ca
spanning-tree mode pvst
no spanning-tree vlan 2003-2009
vlan 2000
vlan 2001
 name Yesnet_Wired
vlan 2002
vlan 2003
 name tc_Wireless
vlan 2004
 name st_Wireless
vlan 2005
 name Guest_Wireless
vlan 2006
 name IOT
vlan 2007
 name VOIP_&_BPI
vlan 2008
 name SPARE
vlan 2009
 name SPARE2
vlan 2100-2102
vlan 2103
 name YESNET_Wired_TPC
vlan 2104-2115
vlan 2116
 name YESNET_Wi-Fi_TPC
vlan 2117-2123
vlan 2124
 name TPC-Wi-Fi
vlan 2125-2129
vlan 2180
 name VCS
vlan 2181-2209
vlan 2270
 name CKE
vlan 2271-2289
vlan 2480
 name SES
vlan 2481-2499
ip ssh time-out 60
interface TenGigabitEthernet5/0/1
 description link to SES
interface TenGigabitEthernet5/0/2
 description Uplink to CKE
interface Vlan10
 ip address 10.160.0.110 255.255.255.0
interface Vlan2100
 description YESNET management
 ip address 10.64.100.200 255.255.255.0
interface Vlan2101
 description M-LAN-DHCP1
 ip address 10.64.101.253 255.255.255.0
ip default-gateway 10.64.100.254
no ip http server
end
