DHCP relay problems
lindaramdani
Community Member
I got some problems with DHCP relay, I hope somone can help me out!
I've set up the environment in my lab and get the same result:
* Client (set to DHCP)
* Router 1 (Cisco 871) (LAN IP-add (VLAN1): 1.1.1.1/8)
* Router 2 (Cisco 871) (LAN IP-add: 3.3.3.1/8)
* DHCP-server (IP-add: 3.3.3.3/8)
I set the IP helper command on VLAN 1 on Router 1 to 3.3.3.3.
With Etherreal on the client I can see the DHCP-discover-packets go out.
And with Etherreal on the DHCP-server I can see the discover-packets arrive and dchp-offer-packets go back out.
With 'debug ip udp', 'debug ip dhcp packet' and accesslists set to the interfaces with log command on the interfaces on Router1 I can see the dhcp-offer arrive, but the Router1 doesn't forward this information to the client.
Instead the router sends back an ICMP - UDP Port unreachable to the DHCP server?!?
Can someone please explain to me what's going on here? 🙂
22 Replies 22
ankbhasi
Hi Friend,
Can you confirm if you see "ip bootp server" command on your any of the routers?
Ankur
Hi!
Yes, 'ip bootp server' and 'service dhcp' is set on the routers, although I can't see it printed out in the config (I guess it's the default settings and therefore not printed out).
Hi Friend,
Can you run "no ip bootp server" command and update with the result.
Ankur
Hi!
Thanks for your suggestion. I tried to turn bootp server off with your command, but there's no difference in the output.
The DHCP-server still recieves ICMP Type:3 Code:3, Port unreachable from Router1 when trying to send the dhcp-offer back to the client.
In Router 1 I see the following output:
DHCPD: BOOTREQUEST from forwarded to 3.3.3.3.
UDP: rcvd src=3.3.3.3(67), dst=1.1.1.1(68), length=340
and after that nothing happens!
/linda
Does anyone else have any idea what is causing my problem?
Linda
Posting the config of the router might enable us to find something that would explain this.
Rick
Rick
Hi Rick!
(Back from the holidays now, hence a late reply.)
Sure thing I can post the config, but it's nearly empty since it's a lab config. I've set it up just to test this thing.
The router is a 871 and Version 12.4(6)T5. The dhcp-client is connected to Fa0.
I also post the output from the 'debug ip udp' command.
Jan 4 15:24:47.663: UDP: rcvd src=0.0.0.0(68), dst=255.255.255.255(67), length=308
Jan 4 15:24:47.663: UDP: sent src=1.1.1.1(67), dst=3.3.3.3(67), length=308
Jan 4 15:24:47.679: UDP: rcvd src=3.3.3.3(67), dst=1.1.1.1(68), length=340
Jan 4 15:24:55.663: UDP: rcvd src=0.0.0.0(68), dst=255.255.255.255(67), length=308
Jan 4 15:24:55.667: UDP: sent src=1.1.1.1(67), dst=3.3.3.3(67), length=308
Jan 4 15:24:55.683: UDP: rcvd src=3.3.3.3(67), dst=1.1.1.1(68), length=340
version 12.4
no service pad
hostname Router1
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
no aaa new-model
resource policy
ip cef
interface FastEthernet0
no cdp enable
spanning-tree portfast
interface FastEthernet1
shutdown
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface FastEthernet4
ip address 2.2.2.1 255.0.0.0
duplex auto
speed auto
interface Vlan1
ip address 1.1.1.1 255.0.0.0
ip helper-address 3.3.3.3
ip route 0.0.0.0 0.0.0.0 2.2.2.2
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
transport output all
line aux 0
line vty 0 4
transport input all
scheduler max-task-time 5000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Linda
Thanks for posting the additional information. I do not see anything in the config that explains the behavior. I wonder if a show interface of the interface the client is connected to and of the VLAN interface would show us anything useful?
I also wonder if the output of debug dhcp (in addition to the debug ip dhcp which you already ran) would tell us anything? And if those do not show anything useful I would ask that you do debug ip packet and post the output.
Rick
Rick
Hi Rick!
Thanks for taking your time trying to help me!
Here follows the output you requested except output from debug dhcp which showed nothing at all. I also added the output of debug ip icmp to show that the router, as mentioned in my first post, is sending an icmp port unreachable back to the dhcp-server for some reason?
FastEthernet0 is up, line protocol is up
Hardware is Fast Ethernet, address is 0017.5922.738c (bia 0017.5922.738c)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s
Last input 00:02:58, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 1 packets/sec
265 packets input, 35436 bytes, 0 no buffer
Received 235 broadcasts, 0 runts, 0 giants, 0 throttles
148 packets output, 9472 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 0017.5922.738c (bia 0017.5922.738c)
Internet address is 1.1.1.1/8
Last input 00:00:17, output never, output hang never
251 packets input, 33126 bytes, 0 no buffer
Received 251 broadcasts, 0 runts, 0 giants, 0 throttles
4 packets output, 240 bytes, 0 underruns
0 output errors, 1 interface resets
debug ip packet
Jan 5 09:36:37.799: IP: s=0.0.0.0 (Vlan1), d=255.255.255.255, len 328, rcvd 2
Jan 5 09:36:37.799: IP: tableid=0, s=1.1.1.1 (local), d=3.3.3.3 (FastEthernet4), routed via FIB
Jan 5 09:36:37.799: IP: s=1.1.1.1 (local), d=3.3.3.3 (FastEthernet4), len 328, sending
Jan 5 09:36:37.815: IP: tableid=0, s=3.3.3.3 (FastEthernet4), d=1.1.1.1 (Vlan1), routed via RIB
Jan 5 09:36:37.815: IP: s=3.3.3.3 (FastEthernet4), d=1.1.1.1, len 360, rcvd 4
Jan 5 09:36:37.815: IP: tableid=0, s=1.1.1.1 (local), d=3.3.3.3 (FastEthernet4), routed via FIB
Jan 5 09:36:37.815: IP: s=1.1.1.1 (local), d=3.3.3.3 (FastEthernet4), len 56, sending
(and then it starts all over again)
debug ip icmp
Jan 5 09:38:06.451: ICMP: dst (1.1.1.1) port unreachable sent to 3.3.3.3
Jan 5 09:38:10.447: ICMP: dst (1.1.1.1) port unreachable sent to 3.3.3.3
Jan 5 09:38:18.451: ICMP: dst (1.1.1.1) port unreachable sent to 3.3.3.3
Jan 5 09:38:34.455: ICMP: dst (1.1.1.1) port unreachable sent to 3.3.3.3
Hello
If I understand you correctly, the discovers arrive at router 2 and the offers are send out of router 2.
Dou you see them arriving at Fa4 at router 1?Since you work with static routes, is there a route from R2 to R1?
Could you post the R2 config?
Is R2 pingable from R1?
Greetings
Can you try this option, instead of assign a helper address to the vlan interface,use the vlan interface to connect to the other router.And the routed port Fa4, to be connected to the LAN with ip helper configuration.
This is just a try and i assume there may be limited functionality for switch ports than a routed port in such router models.
Jay
If the problem still not solved. Can you ping from this router to the DHCP server, i.e. 3.3.3.3 ? Can you also provide a trace route from router 1 to DHCP server ?
Can configure a static IP at the PC and try to ping from the PC to the DHCP server ?
Agreed w/ Fred that please check the return path from the DHCP server back to this router LAN. e.g. gatway at DHCP server, or route from remote router back to this router LAN (VLAN 1).
Are two routers using 2.2.2.x for interconnection ? Or via other routers ?
Hope this helps.
Jack
Your questions seem oriented to it being a problem of connectivity between the two routers. Would you not agree that this debug from an earlier post in this thread shows the packet being sent and a response being received (successful connectivity between the routers):
I believe that the problem is something local to the router (or perhaps to the client). But the config posted does not have anything that looks like a config problem to me. Can you see anything in it?
Linda - I am wondering about the possibility that you are hitting some bug. Is it possible to try a different version of IOS in the router?
Rick
Rick
Hi Rick, I remember that case but able to find it out. I agreed it may be similar reason, i.e. I have cannot find config. issue on the NAT too from the exsiting info. So I asked for the design, if I have another router config then I can guess the connectivity.
Any idea from you other than the IOS ver. ?
Many thx.
