DHCP won't load
Cisco__guy
Hello guys,
i just configured one Router and activated the DHCP, somehow when i connect device to this router it doesn't recieve IP from the router
its comes with 192.16.0.0 and Gat 255.255.0.0
please find the below is my DHCP settings from the config file
no ip dhcp use vrf connected
ip dhcp excluded-address 10.129.1.113
ip dhcp pool aPool
  network 10.129.1.112 255.255.255.240
  default-router 10.129.1.113
  dns-server 10.64.20.59 10.64.20.60
thank you for helping me fix this problem
18 Replies 18
the extra line is for VPN thank you
wihtout this i'll can't create the tunnel using this modem,
hi peter,
In the line of the access-list which you are trying to add there appears to be an additional digit which is causing the problem.
you are trying to add the following;
access-list 101 permit ip 10.129.1.192 2 0.0.0.15 any
the digit I have highlighted here is causing the problem, you do not need this
enter the following;
access-list 101 permit ip 10.129.1.192 0.0.0.15 any
Hope this helps
Hi Peter,
Can do a copy and paste for this particular line in order to prevent typo error?
yes i did already
its add all the line beside the access-list 101
i am doing something wrong?
