DHCP wont run on 877W-M
Dennis Wieringa
i have a 2nd hand 877W-M, updated the bootloader and iOS to the latest.
and now im trying to configure the DHCP, as it looks to me, that is done now, and should be 'working'.
but i dont get any ip's given, and the weird part is that it trows an error right after the 'write' command.
i also have resetted the router to 'conf-register 0x2101' but when it reloads it goes to 36** something.
as for the error it trows in after 'write' its '% IP addresses may not be configured on L2 links.'
here's the version on how its running now:
Using 3350 out of 131072 bytes
! Last configuration change at 07:45:46 UTC Sat Mar 27 2010
version 15.1
no service pad
hostname 877W-M
boot-start-marker
boot bootstrap tftp system 255.255.255.255
boot system flash:c870-advipservicesk9-mz.151-4.M6.bin
boot system flash c870-advipservicesk9-mz.151-4.M6 <i will remove this tonight, i just saw it here>
boot system flash
boot-end-marker
enable secret 5 *****
enable password *****
no aaa new-model
crypto pki trustpoint TP-self-signed-2740876176
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2740876176
revocation-check none
rsakeypair TP-self-signed-2740876176
crypto pki certificate chain TP-self-signed-2740876176
certificate self-signed 01
        quit
dot11 syslog
ip source-route
no ip routing
ip dhcp excluded-address 192.168.2.0 192.168.2.20
ip dhcp pool lan.local
network 192.168.2.0 255.255.255.0
default-router 192.168.2.3
dns-server 192.168.2.3
ip dhcp update dns
no ip cef
no ipv6 cef
archive
log config
  hidekeys
username cisco password 0 cisco
interface ATM0
no ip address
no ip route-cache
shutdown
no atm ilmi-keepalive
cdp enable
interface FastEthernet0 <interface im wating to use for the ip, 192.168.2.3>
no ip address
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Vlan1
no ip address
no ip route-cache
shutdown
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
control-plane
line con 0
exec-timeout 0 0
no modem enable
speed 115200
line aux 0
line vty 0 4
password *****
login
transport input all
scheduler max-task-time 5000
end
im guessing im overlooking something simple, but i dont have the experience with router yet, thats why i have bought this type
2 Accepted Solutions
cadet alain
-reenable ip routing:
config t
ip routing
-As Paolo stated if you want to use both the ethernet and wireless you'll have to bridge them:
bridge 1 protocol ieee
bridge irb
bridge 1 route ip
int bvi1
ip add 192.168.2.3 255.255.255.0
int vlan 1
bridge-group 1
Alain
Jeff Van Houten
Level 5
Level 5
In the first example, in the dhcp pool, you have the network defined. In the second example, you don't. Put the network statement into the dhcp pool.
5 Replies 5
paolo bevilacqua
You configure everything under vlan 1, but if you want to use wireless, bridge it and vlan 1,configure BVI 1 instead.
Note, a self-generate certificate is not sensitve information. Nobody can do anything it.
cadet alain
config t
ip routing
bridge irb
bridge 1 route ip
int bvi1
int vlan 1
bridge-group 1
Alain
Jeff Van Houten
Level 5
Level 5
The router is not going to hand a dhcp address to one of its own interfaces. Hard code the address on the fa address and leave the dhcp for the clients.
okay, i will leave it for the clients, but i ran into a issue regarding the clients.
when i connect to the ssid, with client dhcp, i get an 255.255.0.0 masked ip, and when i assing a static ip, dns, ect to the client and connect then with the ssid, i get the notice that that is working.
im using the ip's in the dhcp pool, because i wanted to use the reserved ip's for other hardware.
this is the config that i have been getting to run thanks to you and cadet
and i found the SDM 2.5, but i actually wanted to learn do it first from the cli, instead of using a 'next, next' gui feature
877W-M>show                    enable
Password:
877W-M#show running c      -config
Building configuration...
Current configuration : 3728 bytes
version 15.1
no service pad
hostname 877W-M
boot-start-marker
boot-end-marker
enable secret 4 *****
no aaa new-model
clock timezone GMT 1 0
--More--                            enrollment selfsigned
subject-name cn=IOS-Self-Signf-signed-2740876176
            quit
dot11 syslog
dot11 ssid C-TEC-877W
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 53+gdg12
ip source-route
ip dhcp remember
ip dhcp update dns
ip cef
ip address-pool dhcp-pool
no ipv6 cef
username management privilege 15 password 0 15104
bridge irb
interface ATM0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
encryption vlan 1 mode ciphers aes-ccm
ssid C-TEC-877W
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
world-mode dot11d country NL outdoor
interface Dot11Radio0.1
encapsulation dot1Q 1 native
ip virtual-reassembly in
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 192.168.2.3 255.255.255.0
ip nat inside
ip http server
control-plane
bridge 1 route ip
line con 0
exec-timeout 0 0
no modem enable
speed 115200
line aux 0
line vty 0 4
exec-timeout 40 0
privilege level 15
login local
transport input telnet ssh
end
Jeff Van Houten
Level 5
Level 5
