Dial Backup on 805 router
gustavo
I have a 805 router connected to a privated leasead line in the serial interface (hdlc protocol). I need Dial Backup for this serial link. This is possible with the console port?
spremkumar
Level 9
Level 9
hi
Its not possible to make use of the console port for dial back up purpose.
Also Cisco 805 series router has reached EOL/EOS and dont support more than 512Kbps.
Would suggest to look out for an upgrade so that you can have both backup as well as higher bandwidth capacity support.
regds
Thanks for the response.
I find in this documentation too, more informations: http://www.cisco.com/en/US/partner/tech/tk801/tk36/technologies_tech_note09186a008009428b.shtml
* You cannot use a console port for dial-on-demand routing because it has no corresponding async interface.
