09-23-2008 04:38 AM - edited 03-03-2019 11:39 PM
we configured DDR Backup over ISDN for an IPSec-connection using dialer-watch. We defined a route to be watched and also interesting traffic.
When the route is deleted from the routing table, the router dials the backup connection as intended and traffic is rerouted over the BRI-Interface.
But every 60 seconds, the router disconnects the call, checks for the primary route and then reestablishes the call.
Is this default behaviour? I would have expected the router to check periodically for the primary route, but i don't think it is necessary to tear down the call for this purpose.
Is there a timer setting which keeps the call up while checking for the primary route or anything similar.
Sebastian
09-23-2008 04:53 AM
dialer watch-disable xx
This delays disconnecting the backup interface for xx seconds after the primary interface is found to be up, that is xx seconds after the idle timeout expired after the primary link came UP.
09-23-2008 04:56 AM
thanks for the quick response.
Sorry if i didn't point that out right: The backup call is disconnected although the primary link is still down.
Do You think this timer will affect this problem although?
Sebastian
09-23-2008 05:00 AM
If you don't have it in the config, put it an see what it does. Alternatively, you can post your Primary Link, BRI and Dialer config.
Off to play COD4, see ya later :)
09-23-2008 05:06 AM
I will try that soon. Anyway, here is the config:
interface BRI0/1/0
description ISDN-Backup
ip address x.x.x.x x.x.x.x
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
ip ospf network broadcast
ip ospf cost 9999
ip ospf priority 0
dialer map ip x.x.x.x name x broadcast x
dialer load-threshold 1 either
dialer watch-group 1
dialer-group 1
isdn switch-type basic-net3
isdn point-to-point-setup
ppp multilink
access-list 100 deny ospf any any
access-list 100 permit ip any any
dialer watch-list 1 ip x.x.x.x x.x.x.x
dialer-list 1 protocol ip list 100
