Difference between Cisco 892FSP & Cisco 891F-K9
aronseo6
Dear All
I would like to know the difference between 892FSP and 891F-K9 routers. Once of our service provider asked us to provide 892FSP router, However supplier has quoted for 891F-K9
Both these are similar in functionality or is there any difference. We need these routers to connect our branches with MPLS on Fiber
Aron
2 Accepted Solutions
Deepak Kumar
Here is the Data-sheet and you will find all required details:
https://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/data_sheet_c78-519930.html
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Seb Rupik
Hi there,
The FSP is certainly the lesser of the two models, check the datasheet for the 890:
Model
WAN Interfaces
LAN Interfaces
802.11a/g/n Option
Integrated USB 2.0/AUX/Console
Integrated Dial Backup
Cisco 892FSP
1-port GE or 1‑port SFP
1-port GE
8-port 10-/100-/1000-Mbps managed switch
No
Yes
No
Cisco 891F
1-port FE
8-port 10-/100-/1000-Mbps managed switch (4‑ports PoE capable with 125W power supply adapter)
Yes
Cisco CleanAir technology
Yes
V.92 analog modem
ISDN BRI
cheers,
Seb.
Deepak Kumar
Deepak Kumar
Deepak Kumar,
Thank you Deepak
Seb Rupik
Hi there,
Model
WAN Interfaces
LAN Interfaces
802.11a/g/n Option
Cisco 892FSP
1-port GE
No
Yes
No
Cisco 891F
1-port FE
Yes
Yes
V.92 analog modem
ISDN BRI
cheers,
Seb.
aronseo6
Thank you Seb
