TestUnusedPortLoopback Port(s)[xxx] failed on a 6500
sudeera_mit
Hi All,
We are having a Cisco 6500 with a Sup720 and running IOS 12.2(33)SXH6.
In switch log we see a below log which has continuousely appeared from few weeks back:
%HA_EM-6-LOG: Mandatory.go_unusedportlpbk.tcl: GOLD EEM TCL policy for TestUnusedPortLoopback
%CONST_DIAG-SP-3-HM_PORT_TEST_FAIL: Module module_number TestUnusedPortLoopback Port(s)[some_number] failed. System operation continues.
Can a guru tell me whether this is a severe bug ?
Sudeera.
7 Replies 7
Leo Laohoo
Sounds like a blade failure to me.
Hey We are also getting the same kind of alert our IR switches (cisco 6506) .you said its look like blade failure and when i run the show module <mod no > commmand its showing the online diag status "minor error".please let me know this is minor issue or any critical impact alert
jjfaure
Do you solve this issue and how? I have a similar one with 6509 with 720 supervisor,
Juan
Deepak Kumar
What is output of a command "
show diagnostic result switch all failure
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Kumar,
Only diagnostic result that is not OK is this one of module 1 :
   13) TestUnusedPortLoopback:
      Port  1  2  3  4
            F  .  U  .
          Error code ------------------> 45 (DIAG_CHECK_ETHER_PAK_ERROR)
          Total run count -------------> 565215
          Last test testing type ------> Health Monitoring
          Last test execution time ----> Feb 25 2019 08:56:58
          First test failure time -----> Feb 24 2019 15:40:48
          Last test failure time ------> Feb 25 2019 08:56:58
          Last test pass time ---------> Feb 24 2019 15:39:45
          Total failure count ---------> 960
          Consecutive failure count ---> 960
  ___________________________________________________________________________
Juan
I can see that Module 1, Port 1 is showing fail. What is connected to this port? Is it possible to "Shut" and "No Shut" once?
Deepak Kumar
Deepak Kumar,
Hi Kumar,
This is the most extrange, interface 1 in module 1 is not connected to anything... i suppose it is a bug , but it appears suddenly, device is working fine without alarms several years ago
