Difference between Port Channel and Ether Channel
Hi All,
What is the exact difference between
Port-Channel
and
Ether-Channel
. or if they are same terms.
If the below setup is possible. If yes, please let me know the sample config of the
L3
and the
router1
or any link to the documentation will help.
Also, if the
Port channel
interface will be
 l2
or is it possible to configure it
l3.
Your reply is higly appreciated.
Ravindra K
Peter Paluch
Perhaps just to add a minor comment:
EtherChannel
or
Link Aggregation
is the particular technology that allows you to bundle several links between two devices and use them simultaneously as a single interface. The
Port-channel
is the name of this virtual interface in IOS. This is similar to, say, WiFi as a technology, and "Dot11Radio0" as the name of the interface, or ISDN as a technology, and BRI as an interface name.
Best regards,
Peter
9 Replies 9
rsimoni
Port-channel and ether-channel
are synonyms.
The way you configured your channel is wrong (unless R1 and R2 are some kind of logically
single router/switch
such as N7K vpC or Cat6500 VSS - or for some other corner case scnario).
You need to have 2 or more links from a
 L2 or L3
device bundled together in a
portchannel
terminating to a
SINGLE router or switch.
Riccardo
Hi Riccardo,
So you mean
Port-Channel>=Link Aggregation=Link Aggregation?<
Ravindra K
Hi Ravindra,
Yes, they are all same. In IOS-XR world, they call it bundle-ether.
Port-channel
can be of
L2 or L3
depending on how you configure it.
Madhu
Hi Ravindra,
Port-Channel=Link Aggregation=Link Aggregation?
I guess you meant
Port-Channel=Etherchannel=Link Aggregation?
the answer is yes.
Riccardo
yes you are right. I meant
Thanks Ricardo. It's resolved.
Ravi
Peter Paluch
EtherChannel
or
Link Aggregation
Port-channel
Best regards,
Peter
The
Port-channel
Errr ... Dot11Radio0 and Dot11Radio1 are both physical interface.  Bridged Virtual Interface (BVI) is a virtual interface for both wired and wireless networks.
Leo,
Yes, you're right - I was merely pointing on the difference between a technology and the usual name for the interface to access that technology.
Best regards,
Peter
Thank you All.
It resolves my query.
Ravi
