Client not getting IP from router
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-24-2012 09:57 AM - edited 03-04-2019 03:25 PM
I have a really strange problem. I have 2 2800 series routers configured the same, but with different subnets. One works fine, the other the client can't obtain an IP, and hardcoded, cant ping.
I ran DHCP debug and I can see the router assigning the IP, and I see and ARP entry that matches the MAC of the client.
*Feb 24 11:33:55.915: DHCPD: Sending notification of DISCOVER:
*Feb 24 11:33:55.915: DHCPD: htype 1 chaddr 000a.e40c.d232
*Feb 24 11:33:55.915: DHCPD: remote id 020a0000ac10760101000078
*Feb 24 11:33:55.915: DHCPD: circuit id 00000000
*Feb 24 11:33:55.915: DHCPD: Seeing if there is an internally specified pool cla ss:
*Feb 24 11:33:55.915: DHCPD: requested address 169.254.29.219 is not on subnet 172.16.118.0.
*Feb 24 11:33:57.915: DHCPD: Adding binding to radix tree (172.16.118.6)
*Feb 24 11:33:57.915: DHCPD: Adding binding to hash tree
*Feb 24 11:33:57.915: DHCPD: assigned IP address 172.16.118.6 to client 0100.0ae4.0cd2.32.
Internet 172.16.118.1 - 0021.d8f9.8356 ARPA Vlan120
Internet 172.16.118.6 0 000a.e40c.d232 ARPA Vlan120
On the other router, not a single issue, works just fine, and the configurations are identical except for the subnets.
Bad card maybe? HWIC-4ESW
- Labels:
Other Routers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-24-2012 01:11 PM
I don't think it's a bad card on the router. We don't have much info about the client. But it seems to me that it may have a firewall on that's blocking ICMP.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-24-2012 01:30 PM
Thats what we thought, but we also noticed the LED for data wan't blinking on the card and he could not ping anything, not even the router. When He did an IPconfig, when set to DHCP he had the 169 IP, not the 172 IP that was assigned. He hardcoded an IP, no change. It is as though the transmit to him was bad.
He tried a few different cables, and then connected the machine to the switched network behind the router and got an IP from that network and was able to work. When he switched back with th eknown good cable, same thing as before. He has used this same laptop on the other switch with the same setup and it worked fine. It is pointing to the card as the problem. We tried all ports, no difference.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-24-2012 03:37 PM
Do you have a Ethernet loop back cable? Or can you make one? Plug it in to the port in question you should get a link light. Also make sure that port is in spanning tree port fast. If you do sh diag does the router see the module?
