Difference between "Sh controller t3" and "sh controller serial x/x"
josephjthomas
What is the difference between the commands "Sh controller t3" and "sh controller serial x/x" ?
They are for the same controller but give different outputs.
XXXXXXXXX>sh controllers t3
T3 1/0 is up.
  Applique type is Subrate T3
  No alarms detected.
  MDL transmission is disabled
  FEAC code received: No code is being received
  Framing is C-BIT Parity, Line Code is B3ZS, Clock Source is Internal
  Data in current interval (320 seconds elapsed):
     0 Line Code Violations, 0 P-bit Coding Violation
     0 C-bit Coding Violation, 0 P-bit Err Secs
     0 P-bit Severely Err Secs, 0 Severely Err Framing Secs
     0 Unavailable Secs, 0 Line Errored Secs
     0 C-bit Errored Secs, 0 C-bit Severely Errored Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 P-bit Coding Violation,
     0 C-bit Coding Violation, 0 P-bit Err Secs,
     0 P-bit Severely Err Secs, 0 Severely Err Framing Secs,
     0 Unavailable Secs, 0 Line Errored Secs,
XXXXXXXXX>sh controllers serial 1/0
Interface Serial1/0
Hardware is DSXPNM GT96K
idb at 0x70A20B20, driver data structure at 0x675FA45C
GT96K Port Used 2, SCC Num 2
MPSC Registers:
MMCR_L=0x001B04C0, MMCR_H=0x40000000, MPCR=0x00000000
CHR1=0x00FE007E, CHR2=0x00000000, CHR3=0x000011E2, CHR4=0x00000000
CHR5=0x00000000, CHR6=0x00000000, CHR7=0x00000000, CHR8=0x00000000
CHR9=0x00000000, CHR10=0x00003008, CHR11=0x0083F83C
SDMA Registers:
SDC=0x00003301, SDCM=0x00000080, SGC=0x00000000
CRDP=0x2E568530, CTDP=0x2E568CC0, FTDB=0x2E568CC0
BRG Conf Register=0x00480000
Rx Clk Routing Register=0x00000800 Tx Clk Routing Register=0x00000900
Main Routing Register (MRR) addr=0x4B701A00, val=0x00FFFE3F
GPP Registers:
Conf =0x0000007F, Io =0x00000006, Data =0x7E7E7E47, Level =0x00000000
Conf0=0x0       , Io0=0x0       , Data0=0x7E7EFFFF, Level0=0x0
SUBRATE FPGA Registers (Clear T3/E3):
24674 input aborts on receiving flag sequence
0 throttles, 0 enables
11530 overruns
0 transmitter underruns
0 transmitter CTS losts
349496014 rxintr, 304041902 txintr, 539 rxerr, 0 txerr
0 mpsc_rx, 719 mpsc_rxerr, 0 mpsc_rlsc, 0 mpsc_rhnt, 0 mpsc_rfsc
0 mpsc_rcsc, 719 mpsc_rovr, 0 mpsc_rcdl, 0 mpsc_rckg, 0 mpsc_bper
1 mpsc_txerr, 1 mpsc_teidl, 1 mpsc_tudr, 0 mpsc_tctsl, 0 mpsc_tckg
0 sdma_rx_sf, 0 sdma_rx_mfl, 11530 sdma_rx_or, 24674 sdma_rx_abr, 21520 sdma_rx_no
0 sdma_rx_de, 0 sdma_rx_cdl, 1682864 sdma_rx_ce, 0 sdma_tx_rl, 0 sdma_tx_ur
539 sdma_rx_reserr, 0 sdma_tx_reserr
0 sdma_tx_ur_processed
0 rx_bogus_pkts, rx_bogus_flag FALSE
0 verilink_runts
tx_limited 0, mci_txcount 128, errata19 count1 0, count2 0
txd_incomplete_count = 0
Receive Ring
rxr head (45)(0x2E568530), rxr tail (0)(0x2E568260)
  rmd(2E568260): nbd 2E568270 cmd_sts 80800000 buf_sz 05E00000 buf_ptr 2E586400
  rmd(2E568270): nbd 2E568280 cmd_sts 80800000 buf_sz 05E00000 buf_ptr 2E573800
    <TRUNCATED>
paolo bevilacqua
Output is different because hardware and circuit have different characteristics.
Howver in most cases the only infromation you are intrested is if the controller status: up or down.
Sh controller t3 is for a Time-Division Multiplexed DS3 usually from the carrier.
sh controller serial x/x is for the serial data side of the circuit.
Carrier digital signal circuit vs. Serial Data Circuit
