Different queueing strategy in ima-group
t-hata
We have 4 T1 circuits which are bundled into ATM/IMA group.
However, I found the guy set first two interfaces have weighted fair as the Queueing strategy, and last two have Per VC Queueing.
I think the grouped interfaces should have same queueing strategy, but I wonder what kind of problems will occur under my circumstance?
Does anyone have an idea?
mohindersingh
Hi Buddy,
I think you should be checking the queuing stratergy on the IMA interface not on physical interfaces.
if you have applied policy-map with CBWFQ on the IMA interface, it should be reflected on IMA interface, not on physical.
Mahi
Hi Mahi,
Thanks for your reply. I confirmed the IMA interface set to Per VC queueing.
But it seemed any policy-map applied to it.
Does this queueing strategy on IMA interface override the queueing strategy on each physical interface?
Hata
