T3 upgrade
rob.bryson
I currently have a Cisco 2600, IOS v12.2(5d) with one WIC-1DSU-T1 interface card. I'd like to upgrade (or add, depending on what the carriers says) this circuit to a T3. What interface card would I need to add? Thanks in advance for any help.
Collin Clark
Here's the card you will need. Make sure you check the platforms that are supported.
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps4909/product_data_sheet09186a008010fba2.html
Hope that helps.
Joseph W. Doherty
Something to keep in mind, a 2600 isn't really suitable for pushing a T3 to full capacity.
