Disable tcp ports 1720, 2001, 6001, 9001 - how?
kstamandk
NERC CIP standards require us to disable unnecessary ports on routers. NMAP SCANs showing;
1720/tcp open  H.323/Q.931
2001/tcp open  dc
4001/tcp open  unknown
6001/tcp open  X11:1
9001/tcp open  tor-orport
Can anyone point me or reply with commands to disable whatever service(s) is causing these to show as open?
2811 running c2800nm-advipservicesk9-mz.124-15.T3.bin
5 Replies 5
vmiller
Level 7
Level 7
Have you disabled these ports at the workstation/server level ?
How many routers do you have on your network ?
kstamandk
TCP Ports 2001, 6001, 9001 turned out to be due to the AUX port configuration. Changing the AUX port to TRANSPORT INPUT NONE corrected those.
Now, any ideas on 1720?
hi,
H.323 is VoIP control protocol. what IOS version are you running? Is this a voice gateway or gatekeeper?
Regards.
Alain.
Router is neither gateway or a gatekeeper, at least not by design. Out of the box, with a very basic configuration when we noticed tcp 1720.
Only configuration item we see is
voice-card 0
  no dsparm
Turns out tcp 1720 was NOT open and it was a firewall that was answering on behalf of the router. Firewall rule updates corrected the issue.
Problem solved.
