disabling inter-VRF routing on IOS router
Mikolaj Moryto
Hi All,
I am trying to setup a router (1921) with two VRFs in my lab and having problem with disabling inter-VRF routing on it.
Configuration:
Current configuration : 2049 bytes
! Last configuration change at 15:32:42 UTC Sat Feb 22 2020
version 15.7
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip vrf VRF0
 rd 65000:0
ip vrf VRF1
 rd 65000:1
ip cef
no ipv6 cef
license udi pid CISCO1921/K9 sn FJC1922E0AT
redundancy
interface Tunnel0
 ip vrf forwarding VRF0
 ip address 1.1.1.1 255.255.255.252
 tunnel source GigabitEthernet0/0
 tunnel destination 192.168.140.51
 tunnel vrf VRF0
interface Tunnel1
 ip vrf forwarding VRF1
 ip address 1.1.1.2 255.255.255.252
 tunnel source GigabitEthernet0/1
 tunnel destination 192.168.120.51
 tunnel vrf VRF1
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.120.51 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 192.168.140.51 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/0/0
 no ip address
interface GigabitEthernet0/0/1
 no ip address
interface GigabitEthernet0/0/2
 no ip address
interface GigabitEthernet0/0/3
 no ip address
interface Vlan1
 no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
no ip route static inter-vrf
ip route vrf VRF0 0.0.0.0 0.0.0.0 192.168.120.254
ip route vrf VRF1 0.0.0.0 0.0.0.0 192.168.140.254
control-plane
 vstack
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input none
scheduler allocate 20000 1000
end
Both interfaces of the router are connected to the same L3 switch that performs inter-VLAN routing. I enabled some debugs and captures on the L3 switch and when pinging between router's Gig0/0 and Gig0/1 it does not traverse the L3 switch. Also when pinging GRE tunnel IPs I cannot see the traffic on the L3 switch so to me it seems that the traffic goes directly. Any idea how can I stop this and force the traffic between VRFs to flow through L3 switch all the time?
Thanks!
It could be because when you ping the SVI the packets need to be switched in software so the debugs show them whereas when you ping between routers assuming the packets are going via the switch they are hardware switched so the debugs may not pick them up.
Why not just apply an inbound acl on the one of the SVIs on the L3 switch blocking ICMP and then try pinging and see if it works.
If it doesn't then remove the acl and if then works you can be pretty sure your traffic is going via the switch which looking at your topology it should be.
Jon
8 Replies 8
not sure what you are asking...by default, VRFs cannot talk to each other.
Can you post the configuration of the layer 3 switch ? What exactly are you trying to accomplish ?
That was my understanding but when trying to ping between Gig0/0 and Gig0/1 IP addresses and running the debug ip icmp on L3 switch I cannot see it. I can see the packets when pinging SVI IP address though so debug seems to be working.
I would expect that when running:
Router#ping vrf VRF0 192.168.140.51
it would go to the L3 switch, be routed between VLANs, and then reach the router via Gig0/1. Is that correct or my understanding is incorrect? Ping is going through but it does not show in the debug run on the switch.
L3 switch configuration below.
Router's Gig0/0 is connected to Gig0/2 on the switch.
Router's Gig0/1 is connected to Gig0/4 on the switch.
ip routing
port-channel load-balance src-dst-ip
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 110,120,130,140,150,160,1610,1620,3210,3220
ip ssh version 2
class-map match-all disabled
interface GigabitEthernet0/2
 switchport access vlan 120
 switchport mode access
 switchport nonegotiate
 power inline never
interface GigabitEthernet0/4
 switchport access vlan 140
 power inline never
interface Vlan120
 ip address 192.168.120.254 255.255.255.0
 ip helper-address 172.16.10.1
 ip helper-address 172.16.10.2
interface Vlan140
 ip address 192.168.140.254 255.255.255.0
Anyone? Maybe they way I am verifying this is incorrect but I cannot see the traffic between VRFs traversing L3 switch.
Thanks!
I think either your setup or your question is unclear. You cannot ping between VRFs. How is the layer 3 switch involved here ? Post a diagram showing your topology...
Diagram below. I can ping and I would expect it should traverse the L3 switch but looking at "debug ip icmp" it doesn't look like it is traversing it.
Debug IP ICMP on the switch is not showing the traffic.
Is there other way I should be verifying this?
Jon
Thank you. That was what made me thinking the traffic does not flow through the switch but adding the ACL on the switch resulted in ping not going through so that confirms it actually goes via the switch as expected.
Thanks!
Cristian Matei
    This command (no ip route static inter-vrf) will make the router ignore any inter-vrf routing achieved via static routes; the routes can be configured, but are not used. What you're doing is something else:
           - first of all your static routes are configured for intra-vrf routing, not inter-vrf routing
           - you're achieving VRF leaking because you make use of an external L3 device where VRF's have not been extended
           - since you ping between the router's interfaces in different VRF's, the switch will CEF switch your ICMP packets, it's expected you see nothing on debug icmp
Cristian Matei.
