05-20-2009 08:31 PM - edited 03-04-2019 04:49 AM
Hello
I have a link with 2 cisco routers on either end. The link is 2Mbps in size and I would like to take about 128Kbps off that line but still let it run over the same line using the same routers.
I want to route all my traffic over the 1920K line and nothing over the 128K.
So if the 1920Kbps link is full I can still reach the remote router by using the 128K part of the bandwidth.
I would like to know what this setup is called please? Technically it is not load balancing, although I recall having seen this done, but forgot the technical term.
Any help much appreciated.
Solved! Go to Solution.
05-20-2009 09:07 PM
It is not possible to be very granular in BW with the pre-MQC methods. Beside, they are now deprecated.
If you have channelized hardware, you can configure different channel-groups to statically divide BW, but that is not a very good idea because the non-priority traffic will be unable to use all the physical circuit not even when there is no priority traffic. And the priority traffic will be slower all the time (longer serialization time).
Please remember to rate useful posts with the scrollbox below.
05-21-2009 08:26 AM
According to the previous post, he's right. Modular QoS is the way to do what you want to. If your router doesn't support it, you may need to do an IOS update. The later IOS versions will support CBWFQ which will allow you to be able to segment your traffic, apply shaping/policing on that traffic, and prioritize traffic.
HTH,
John
05-20-2009 08:35 PM
It's called QoS modular CLI. You ACL the traffic you want to give a certain BW, apply the policy to the interface and you're done. Find examples with the CCO searchbox.
05-20-2009 08:57 PM
Thanks for teh quick reply. I recall this setup being done about 8 or so years ago, before QoS was introduced. Any other (non-QoS modular CLI) ideas?
Thanks again for the help.
regards
willemvw
05-20-2009 09:07 PM
05-21-2009 08:11 AM
Regarding the rating to my post above:
The information I gave is 100% correct.
On the other hand, the attitude shown in low rating it, needs major adjustment.
Do not vent your frustration on who tells you the truth just because it is not what you wanted to hear.
05-21-2009 08:26 AM
HTH,
John
05-21-2009 04:25 PM
I am sad to say that I have not yet entered ANY ratings for this post. I understand you are not aiming at an individual in specific, but I would like to add that I find this forum extremely helpful and usually rate either a 5 if it solves my problem. Or I just don't give a rating if I didn't find what I was looking for.
For this posting, you have solved my problem and I would like to thank you for your time and effort you have put in to get me on the right track! :)
willemvw
05-21-2009 05:00 PM
You're very welcome! Hope it helps and you get your problem resolved :-)
John
05-21-2009 09:26 PM
Willem,
please excuse me if it looked like I was assuming the low rating came from you.
Thank you and good luck!
