DMVPN + EIGRP neighbor not found
the-lebowski
Level 4
Level 4
Hello
Moving from LAB to production and I cannot get the HUB router to participate in EIGRP.  I see in the logs neighbor not found (10.1.2.192) which is the spoke's tunnel interface.
HUB:
interface Tunnel1
ip address 10.1.2.1 255.255.255.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 3111
no ip split-horizon eigrp 3111
ip nhrp authentication TEST
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp holdtime 300
ip tcp adjust-mss 1360
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 123
tunnel protection ipsec profile TEST-DMVPN shared
router eigrp 3111
network 10.0.0.0
eigrp router-id 10.120.0.10
r4-2911-HUB#show ip eigrp neighbors
EIGRP-IPv4 Neighbors for AS(3111)
Sep  3 23:18:21.264: EIGRP: Neighbor(10.1.2.192) not yet found
SPOKE:
interface Tunnel1
ip address 10.1.2.192 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 10.1.2.1 205.234.20.11
ip nhrp nhs 10.1.2.1
tunnel source GigabitEthernet0/1
tunnel key 123
router eigrp 3111
network 10.0.0.0
eigrp stub connected
H   Address                 Interface              Hold Uptime   SRTT   RTO  Q  Seq
                                                   (sec)         (ms)       Cnt Num
1   10.1.2.1                Tu1                      13 00:00:10    1  5000  1  0
2   10.192.11.1             Gi0/0.1                  14 00:07:05   16   100  0  39
0   10.192.2.1              Gi0/0.2                  14 00:07:06  148   888  0  36
*Sep  3 23:19:18.675: Going down: Peer 10.1.2.1 total=2 stub 0, iidb-stub=0 iid-all=0
*Sep  3 23:19:18.675: EIGRP: Handle deallocation failure [1]
*Sep  3 23:19:18.675: EIGRP: Neighbor 10.1.2.1 went down on Tunnel1.
*Sep  3 23:19:22.943: EIGRP: New peer 10.1.2.1.
*Sep  3 23:19:22.943: %DUAL-5-NBRCHANGE: EIGRP-IPv4 3111: Neighbor 10.1.2.1 (Tunnel1) is up: new adjacency...
Can someone help me out?  I for the life of me cannot figure out why the spoke can peer but the HUB cannot.
Peter Paluch
Usually, the spoke is configured also with the ip nhrp map multicast 205.234.20.11 on its mGRE interface. I do not see this line in your spoke's configuration - would you mind adding it?
Also, do you happen to use any neighbor command in your EIGRP configuration either on the spoke or on the hub?
Best regards,
Peter
6 Replies 6
Peter Paluch
Best regards,
Peter
Thanks Paul that is exactly what it was, once that was added it was able to form.
I don't use any neighbor commands at all.
Hi guys, just wanted to add my solution to the problem. I had the same symptoms:EIGRP neighbor not found on a DynamicMultipoint VPN.
My setup was slightly different, because I also had defined the ip nhrp map multicast destination on the spokes:
ip nhrp map multicast x.x.x.x
Adding the eigrp neigbour did not solve my problem.
I found that I had misconfigured ip nhrp map multicast x.x.x.x : I had used the GRE address of the hub, but that should have been the interface IP of the hub. Once I had changed that, neigbourships were formed immediately :)
Thanks Peter. I incorrectly mapped spoke nhrp multicast to hub DMVPN tunnel interface IP. The result is EIGRP neighbor comes up on spoke but flaps (retry limit exceeded) because Q cnt never became 0. DMVPN hub never saw spokes in EIGRP neighbor.
When dmvpn multicast come ni tunnel interface (encapsulated) rather than tunnel source, it gets discarded?
Hi John,
In my hub location i have single router with one public ip natted with local ip & i have 2 isp.
When primary isp is up dmvpn is working fine. when primary isp is down dmvpn is not coming up. i have observed tunnel are up qm_ideal. But eigrp routes are not receving on secondary link.
I was missing neighbor statement under eigrp config, adding this solved my problem as well!
