DMVPN over ADSL
wael.kamal
I have acustomer have head quarter and 20 branch connected via L3 MPLS connection and want to deploy a backup link to this solution so he thinks that DMVPN can work over ADSL (internet), I don't know if this is applicable or not.please help.
paolo bevilacqua
Yes it's very applicable and many customers use DMVPN over the Internet, as primary or backup metod of linking branches together.
the customer has routers 1841 at branches and what router series should be the hub and this customer will merge his company with another company has 20 branches this make 40 branch.
what needed router as hub in case of 20 and incase of 40 branches ?
and if you have any configuration exampels for this case i would be thankful if you provide me with this material ?
thank you
It depends by traffic volume more than number of branches. In general the 1841 is fine unless you want to try to upsell and ISR G2.
Please remember to rate useful posts clicking on the stars below.
Hello Wael. A 3845 ISR router should work fine for the hub. I'm attaching a sample hub and spoke config for your review.
pls rate if this helps.
