Help with 3rd gen WIC card
Colin Higgins
Level 2
Level 2
I have a 1-Port 3rd Gen Multiflex Trunk Voice/WAN Int. Card - T1/E1 in a 2901 that I want to configure for data only (T1 connection to the Internet)
I don't see any options in the IOS for using this thing as a serial interface (data), only options for configuring PRI/ISDN
Can anyone help me out here?
5 Replies 5
paolo bevilacqua
In controller config mode, type ? and post output here.
Also mention exact IOS used.
I don't get anything when I type
controller ?
at the config prompt
the IOS version is 15.0(1) M4
and when the system boots, it lists
1 Channelized (E1 or T1)/PRI port
ah, I forgot to specify the card type
now I can see the controller commands
Router(config)#controller t1 ?
  <0-0>  Controller slot number
Router(config)#controller t1 0 ?
% Unrecognized command
this is irritating me
I get
Router(config)#controller T1 0/0
% Invalid input detected at '^' marker.
after specifying the card type
OK, LOL I got it
it is controller T1 0/0/0
all good now
