DMVPN QoS Challenge
philip moore
Dear All,
Trying to figure this put and really struggling. If anyone can offer any advice it would be much appreciated.
The scenario is this:
- the WAN consists of a in-house satellite network using comtech CDM-570 IP-Enabled Satellite Modems
- there is a group of HUB tx modems, each one is shared for approx remote 10 sites with a total bandwidth tx 2048k
- each remote site is to be guaranteed min 512k but can burst into the 2048
- remote sites must be somehow grouped to a member of each modem to set the bandwidth constraints
- a single DMVPN/multipoint GRE is configured on HUB. all remote sites connect to this (redundancy comes later )
The challenge is how to configure the QoS on the HUB side to meet this policy
Currently, I use ip nhrp group MODEM1 on each remote site, and ip nhrp map group MODEM1 service-policy output MODEM1 on the HUB. This is working ok
This works nicely, however I am left with the constraint that within each modem group I must define a class for each site and set the guaranteed bandwidth. As the policy is applied pre-encapsulation, I must create a class with an acl matching the remote sites IP ranges. An administration nightmare and prone to failure! I want to avoid this if possible.
Here is the qos config on hub, this is applied as output policy on LAN interface (i.e. to the tx modem):
policy-map MODEM1-TUNNEL
class SITE1
  bandwidth 512
  service-policy child1
class SITE2
  bandwidth 512
  service-policy child2
policy-map MODEM1
class class-default
  shape average 2048000
  service-policy MODEM1-TUNNEL
The alternative I thought of was to use the nhrp group to apply the child1 policy in the tunnel. Then on the outgoing LAN interface apply a shape policy per tx modem:
class SITE1
  bandwidth 512
class SITE2
  bandwidth 512
class SITE1
  bandwidth 512
class SITE2
  bandwidth 512
policy-map WAN-EGRESS
class MODEM1
class MODEM2
  service-policy MODEM2-TUNNEL
...etc
This is not so bad as all I would need to do is create a class for each SITE with acl match for the GRE tunnel IP addresses, still a bit clunky but certainly more reliable. I did not try this yet and I am bit concerned that the tunnel would use the pre-classified.
Any ideas.
thanks!!!!
paolo bevilacqua
ACL configuration can be quite complicated (and sometime not bring the expected results), especially when there are tunnels and LAN interfaces involved.
So, you need to configure everything punctually, on the other hand is not like the router can know what has to do without being told.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Later IOS versions' DMVPN, supports QoS polices per (physical) hub-to-spoke tunnel.  The remote spoke tells tell the hub what policy to use towards it.  Seems a bit backwards, but if many spokes can use the same policy, it's just defined once as a policy on the hub and the spokes "request" it.
Thanks for the replies.
Yes absolutely, that is exactly the feature I am leveraging here:
Remote:
int tun 0
HUB:
int tun 0
The problem is that I need to somehow group a series of tunnel end points (remote) by their tx modem, apply a shape to the overall group to restrict total b/w to 2048, then for each site connected to that modem apply committed rate per site of 512k.
