RIP Routing not advertising
benschultheis1
I am trying to get RIP Routing to advertise between 3 routers. I think my configuration ois correct but I am not sure. I am a beginner to the network world and have been checking out other threads but nothing seems to be helping. I am attaching my configs along with outputs from some commands. Can someone please steer me in the right direction?
20 Replies 20
Hello, Ben.
Please write a diagram will all the addresses assigned per interface.
I guess you will find the first issue.
Second one is that RIP is not enabled on all the interfaces ( CORE:s0/1/0, CORE s0/3/1).
If you are just learning RIP, then use command network 0.0.0.0
I issued the network 0.0.0.0 command and rip routes are still not being advertised. And how exactly do you enable rip on specific interfaces?
Hello
Richmond
no router rip
ip routing
router rip
version 2
no auo-summary
network 195.131.50.0
Erie
no router rip
ip routing
router rip
version 2
no auo-summary
network 199.122.20.0
Core
Does the core device have reachablilty to both Richmond and Eire over its physical interfaces?
Also disable Automatic network summarization.
ip routing
router rip
version 2
no auo-summary
clear ip route *
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Ben,
For starts, I would suggest doing 'no auto' under the RIP routing process at the hub.
Erie
interface Serial0/3/0
ip address 199.122.20.10 255.255.255.248
encapsulation ppp
I see that interface, as the only interface configured, with an IP address on that router, yet under RIP I see the following.
router rip
version 2
network 189.12.0.0
network 203.167.10.0
network 212.2.40.0
no auto-summary
I don't think the networks advertisd in bold really need to be advertised...
Richmond
Same thing as Erie, I see the following interface, as the only interface configured with an IP address.
ip address 195.131.50.10 255.255.255.248
encapsulation ppp
But under RIP you are advertising all the networks.
Pdriver,
Damnit, got to it first hahahaha..
Hello John
Apologies but i guess thats the beauty of these forums so many people will to help others!
res
Paul
Thanks.
Kind Regards
Paul
First off...Thank You guys.
I made the changes both of you explained but i still cannot get these router to see one another.
PDriver - yes the core router can see both the erie and richmond routers.
Ben
Assuming the core router can ping each of the other routers can you post -
1) "sh ip route" from all routers
2) RIP config from each router (not the whole config just the router bit if you can)
CoreR1#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is not set
     189.12.0.0/16 is variably subnetted, 2 subnets, 2 masks
C       189.12.30.0/29 is directly connected, Serial0/3/0
C       189.12.30.10/32 is directly connected, Serial0/3/0
     195.131.50.0/24 is variably subnetted, 2 subnets, 2 masks
C       195.131.50.8/29 is directly connected, Serial0/1/0
C       195.131.50.10/32 is directly connected, Serial0/1/0
     199.122.10.0/29 is subnetted, 1 subnets
C       199.122.10.8 is directly connected, Serial0/3/1
     199.122.20.0/32 is subnetted, 1 subnets
C       199.122.20.10 is directly connected, Serial0/3/1
     203.167.10.0/24 is variably subnetted, 2 subnets, 2 masks
C       203.167.10.0/29 is directly connected, Serial0/0/0
C       203.167.10.10/32 is directly connected, Serial0/0/0
     212.2.40.0/29 is subnetted, 1 subnets
C       212.2.40.0 is directly connected, Serial0/2/0
     212.4.40.0/32 is subnetted, 1 subnets
C       212.4.40.10 is directly connected, Serial0/2/0
CoreR1#
router rip
version 2
no auto-summary
Erie#sh ip route
     199.122.10.0/32 is subnetted, 1 subnets
C       199.122.10.9 is directly connected, Serial0/3/0
     199.122.20.0/29 is subnetted, 1 subnets
C       199.122.20.8 is directly connected, Serial0/3/0
router rip
version 2
no auto-summary
Richmond#sh ip route
C       195.131.50.8/29 is directly connected, Serial0/3/0
C       195.131.50.9/32 is directly connected, Serial0/3/0
Richmond#
router rip
version 2
no auto-summary
and just so you guys know...there are other routers on this network and rip is not working for any of them. I just figured to use 3 instead of all of them to make it easier to troubleshoot. once I find the fix I will apply to the remaining routers
Ben
Okay, sorry but can you actually post the "sh run" for all three devices and attach them as you did in your original post.
Can you ping from the core router to each of the other routers ?
Jon
Sorry Jon. The configs are below. Also yes I can ping all routers from the Core router.
CoreR1#sh run
Building configuration...
Current configuration : 1135 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname CoreR1
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 203.167.10.1 255.255.255.248
encapsulation ppp
clock rate 64000
interface Serial0/1/0
ip address 195.131.50.9 255.255.255.248
encapsulation ppp
clock rate 64000
interface Serial0/1/1
no ip address
shutdown
interface Serial0/2/0
ip address 212.2.40.1 255.255.255.248
encapsulation ppp
clock rate 64000
interface Serial0/2/1
no ip address
shutdown
ip address 189.12.30.1 255.255.255.248
encapsulation ppp
clock rate 64000
interface Serial0/3/1
ip address 199.122.10.9 255.255.255.248
encapsulation ppp
clock rate 64000
interface Vlan1
no ip address
shutdown
router rip
version 2
no auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Richmond>en
Richmond#sh run
Current configuration : 678 bytes
version 12.4
hostname Richmond
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
encapsulation ppp
no ip address
interface Vlan1
no ip address
shutdown
router rip
version 2
no auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Baltimore#sh run
Current configuration : 674 bytes
version 12.4
hostname Baltimore
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
ip address 212.4.40.10 255.255.255.248
encapsulation ppp
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router rip
network 212.2.40.0
no auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Ben
On the core router you need to add network statements under your RIP config for the networks used to connect to the other two routers.
Jon
Jon,
I agree.
Ben if you look at the below config, you have network statements setup previously for your RIP networks on your CORE router.
router rip
version 2
network 189.12.0.0
network 195.131.20.0
network 212.2.40.0
For the two spokes to come up Erie and Richmond, you need to add the following.
The others you don't technically have to add, if the're are no routers running RIP connected to them, but if you want reachability for those networks within RIP, you will need to add those network commands as well.
*I was just joking with you pdriver. I was thinking when I was typing all that above, I bet someone is doing the same thing as me haha*
