03-25-2010 05:54 AM - edited 03-04-2019 07:55 AM
I have a issue where the packets are not following the routing table.
Oslo router ----------- Trondheim router
l l
l l
Denmark main site router
If the traffic want to reach 10.47.3.x in from OSLO to Trondheim, then the traffic is going over the router in Denmark every time.
I have attach the configuration and sh ip route from the router in OSLO.
We have a lot of other routers in the network and they are working fine, it is only this one. We have also tried to change the router, but it is the same problem.
So it must be some configuration thing.
Hope someone can find the fault.
Solved! Go to Solution.
03-26-2010 06:49 AM
Based on this doc:
It seems you don't support this feature (you need 12.4(15)T min on all your spokes)
Laurent.
03-25-2010 03:20 PM
Has Oslo the right NHRP entry for 10.45.2.9 ? If yes is it able to build the IPSec tunnel ?
Laurent.
03-26-2010 01:38 AM
We have found the reason:
10.45.2.10/32 via 10.45.2.10, Tunnel0 created 2d12h, expire 00:59:38
Type: dynamic, Flags: authoritative unique registered
NBMA address: 193.213.39.175
(Claimed NBMA address: 192.168.1.37)
Because the router in OSLO is sitting on a ADSL line, where it is getting a internal IP from the ISP 192.168.1.37, then hub to hub is not working, only to the central site.
so what workaround can I do here? so it is possible the go true the nat from the ISP, or is it not posible?
03-26-2010 03:47 AM
Dear Erik,
If a router tries to register with a different IP for which hub already has a nhrp cache entry, then usually there is a syslog msg stating this behavior. Are you getting any notifications on your syslog/console ?
03-26-2010 05:58 AM
I have not could find any logs in any of the routers, there would show me any problem.
Erik
03-26-2010 06:49 AM
Based on this doc:
Laurent.
04-06-2010 12:04 AM
Both spokes are running 12.4.24T, so this should not be the issue.
But I can see the central router is running 12.2.23, so maybe this is the issue?
04-06-2010 06:55 AM
It makes sense.
Laurent.
04-16-2010 02:36 AM
Thanks Laurent,
After the upgrade of the central unit, then the feature with NAT from SPOKE to SPOKE worked like a charm..
The same time our 2 routers in OSLO went down, why I don't know, but one went into Rommon mode, and the flash is gone, and the other router was totally dead.....
So our office was down over a weekend, but then we got hold on a 3rd router, this time a 1812W and this works like a charm.
So we was just a bit unlucky with the hardware the same time. :-)
Hope to see you at the networkers in Las Vegas.
Best regards,
Erik Jacobsen
Denmark
