DNS Proxy
infocis
I am searching some information for doing with an 800 router a practical fonctionality provided with the Linksys router family.
Simply relay DNS request from the inside interface IP to the binded name-servers provide by the ISP on the outside interface. So PC's will be able to do dns request (UPD or TCP) with the router address.
Is there any information the would help me to understand how to do it
The ISP
10 Replies 10
pkhatri
Level 11
Level 11
You need to use NAT for this work. Try something like the following (I'm using 192.168.1.0/24 as your LAN network - change this to suit your needs):
interface Ethernet0
ip nat inside
interface Serial0 ! your WAN interface
ip nat outside
ip nat inside source list 10 interface serial0 overload
access-list 10 permit 192.168.1.0 0.0.0.255
Hope that helps - pls rate the post if it does.
Paresh
Thanks Paresh but I have already this one set as default for accessing all Internet services.
The one I need is to translate the Ethernet0 as a DNS service for the inside and in reality, there is a NAT command (or any other) to reach Internet DNS services from the ISP.
I'm not sure I understand what you are trying to achieve. Could you post some details, maybe an example with IP addresses ?
Paresh
Paresh,
Cisco answered with IP DNS command...
Thanks anyway
Sylvain
Paresh,
Thanks anyway
Sylvain
Paresh,
Thanks anyway
Sylvain
Paresh,
Thanks anyway
Sylvain
Paresh,
Thanks anyway
Sylvain
Paresh,
Thanks anyway
Sylvain
Paresh,
Thanks anyway
Sylvain
