Does Cisco 7206 router (15.1(4)M6) support IKEv2 and VTI?
ohforce55
I have a Cisco 7206VXR router and its code is 15.1(4)M6.
I wonder if this box can support IKEv2 and VTI.
Thanks!
in 15.1(4)M6, IKEv2 is supported in Advanced Enterprise Services, Advanced Security, and Advanced IP Services.
VTI has been around since 12.x, so your 7206 should definitely support it.
Are you trying to use the GNS3 version of the 7206 ?
6 Replies 6
Thank you so much for your reply!
No. This is not for GNS3.
Just double checking with you :)
This is the sh ver output of the router. Can you double check if IKEv2 still supports?
7206#sh ver
Cisco IOS Software, 7200 Software (C7200P-ADVENTERPRISEK9-M), Version 15.1(4)M6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 14-Feb-13 08:55 by prod_rel_team
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 15.1(4)M6, RELEASE SOFTWARE (fc2)
7206 uptime is 2 years, 28 weeks, 6 days, 17 hours, 0 minutes
System returned to ROM by bus error at PC 0x346CFBC, address 0x0 at 21:14:26 CDT Mon Oct 19 2015
System restarted at 03:16:07 UTC Tue Oct 20 2015
System image file is "disk2:c7200p-adventerprisek9-mz.151-4.M6.bin"
--> C7200P-ADVENTERPRISEK9-M
You are running Advanced Enterprise Services, so IKEv2 is supported...
Thanks for your reply again.
One more question.
So the switch with the code can support the following ?
encryption aes-cbc-256
integrity sha256
group 14
according to the command reference these are all supported:
--> aes-cbc-256
Specifies 256-bit AES-CBC as the encryption algorithm.
integrity sha256
--> sha256
Specifies SHA-2 family 256-bit (HMAC variant) as the hash algorithm
group 14
--> 14
Specifies the 2048-bit DH group
Thanks a lot!
