Does Cisco has software monitor traffice ?
rechard_hk
Dear all,
Does Cisco has software monitor traffice? ex: clinet have virus and request to Cisco switch, router that we can know which client attack .
Best Regards,
Rechard
nkarpysh
Cisco has many tools to monitor traffic. Each platform may have its own specific tool. Most comman across all platforms are:
Netflow:
http://www.cisco.com/en/US/products/ps6601/products_ios_protocol_group_home.html
and SPAN:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml
If you have some specific platforms you want to check for the available tools - let us know. As I said particular platforms may have additionla tools.
Niko
HTH,
Niko
ashirkar
Level 7
Level 7
Hi Rechard,
You can also use Embedded Packet Capture method to capture packets and then analyze using tool like wireshare .Here is document you can refer for same "Configuration Example: Embedded Packet Capture on Cisco IOS and IOS XE"
Ashish Shirkar
Technical Community Manager - NI
