Does the Cisco ISR4331 support Xconnect functionality on a sub-interface
wood20011
The following is an extract of what I setup using C3745 routers in GNS3. This has been a workable solution:-
The 2 serial links represent 2 x 2Mbps G.703 links over microwave radio links.
I have created 2 logical tunnels which have both been IPSEC’ed.
Tunnel 1 goes over serial interfaces S0/0 and tunnel 2 goes over S0/1 interfaces.
Vlan 100 traffic goes over tunnel 1 and vlan 20 traffic goes over tunnel 2. This keeps the traffic separate.
hostname R1
pseudowire-class R1
encapsulation l2tpv3
ip local interface Tunnel1
pseudowire-class R11
ip local interface Tunnel2
crypto isakmp policy 1
encr aes 256
hash md5
authentication pre-share
group 2
lifetime 36700
crypto isakmp policy 2
encr aes 256
hash md5
group 2
lifetime 36700
crypto isakmp key cisco123 address 10.1.1.2
crypto isakmp key cisco123 address 10.1.1.6
crypto ipsec transform-set TRANS esp-aes esp-sha-hmac
crypto ipsec profile IPSEC
set transform-set TRANS
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Tunnel1
ip address 192.168.10.1 255.255.255.252
tunnel source 10.1.1.1
tunnel destination 10.1.1.2
tunnel protection ipsec profile IPSEC
interface Tunnel2
ip address 192.168.10.5 255.255.255.252
tunnel source 10.1.1.5
tunnel destination 10.1.1.6
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.100
encapsulation dot1Q 100
no cdp enable
xconnect 192.168.10.2 16 encapsulation l2tpv3 pw-class R1
interface Serial0/0
ip address 10.1.1.1 255.255.255.252
clock rate 2000000
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.20
encapsulation dot1Q 20
no cdp enable
xconnect 192.168.10.6 17 encapsulation l2tpv3 pw-class R11
interface Serial0/1
ip address 10.1.1.5 255.255.255.252
clock rate 2000000
hostname R2
pseudowire-class R2
pseudowire-class R22
encr aes 256
hash md5
group 2
lifetime 36700
encr aes 256
hash md5
group 2
lifetime 36700
crypto isakmp key cisco123 address 10.1.1.1
crypto isakmp key cisco123 address 10.1.1.5
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Tunnel1
ip address 192.168.10.2 255.255.255.252
tunnel source 10.1.1.2
tunnel destination 10.1.1.1
interface Tunnel2
ip address 192.168.10.6 255.255.255.252
tunnel source 10.1.1.6
tunnel destination 10.1.1.5
no ip address
duplex auto
speed auto
no cdp enable
xconnect 192.168.10.1 16 encapsulation l2tpv3 pw-class R2
interface Serial0/0
ip address 10.1.1.2 255.255.255.252
clock rate 2000000
no ip address
duplex auto
speed auto
no cdp enable
xconnect 192.168.10.5 17 encapsulation l2tpv3 pw-class R22
interface Serial0/1
ip address 10.1.1.6 255.255.255.252
clock rate 2000000
Moving forward, I wish to use a Cisco ISR4331 router using the same configuartion. Unfortunately, I hit a snag. When I assign the xconnect command to the subinterface on the ISR4331, I cannot ping from 1 laptop to the other. The following commands all say that the tunnels are up and operational.
R1#show crypto isakmp sa
R1#show crypto ipsec sa
R1#show xconnect all
When i apply the xconnect command however to the physical interface, it works.
Am I missing something ?
Francesco Molino
Don't recall if that was on 4331 platform (need to verify on documentation again) but can you test with 2 hosts attached to a trunk interface which will tag packets with the right dot1q vlan and see if the communication goes through.
The limitation was that untagged traffic was not forwarded on xconnect attache to dot1q subinterface.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
Hi Francesco
Your advice was correct. I placed the xconnect command back on the subinterface and ensured that the traffic going in was tagged with the correct vlan tag. I appreciate your help.
Cheers
Mick W
Glad it works that way.
Francesco
