Doing Trunk and Vlan Interfaces in ASR1001X
wanhafizi2012
Dear all,
Currently we've obtained ASR1001X and the new redudancy configuration requires us to pass dot1q traffic through 2 interfaces. It seems we cannot familiarize ourself with trunking and vlan interface when it comes to pure L3 devices.
A diagram of the implementation is as attached.
Thankyou for your help in advance
Elliott Willink
To do this I would use EVC's (http://www.cisco.com/c/en/us/td/docs/ios/ios_xe/cether/configuration/guide/xe_3s/ce_xe_3s_book/ce_evc-infra_xe.pdf)
I'm assuming the config is similar to the ASR900 implementation, which would be as follows:
bridge-domain 10
bridge-domain 20
bridge-domain 30
interface BDI10
    ip address 10.0.1.1 255.255.255.0
interface BDI20
    ip address 10.0.2.1 255.255.255.0
interface BDI30
    ip address 10.0.3.1 255.255.255.0
interface Ten0/0/0
    service instance 10 ethernet
        encapsulation dot1q 10
        rewrite ingress tag pop 1 symmetric
        bridge-domain 10
    service instance 20 ethernet
        encapsulation dot1q 20
        bridge-domain 20
    service instance 30 ethernet
        encapsulation dot1q 30
        bridge-domain 30
interface Ten0/0/1
        bridge-domain 10
        bridge-domain 20
        bridge-domain 30
That should do it. Read up on EVC's and how they are implemented so you understand what is going on above, and can adjust the functionality of the interfaces as you need to. The service provider/EVC functionality is very powerful and you can do some very interesting stuff with L2/L3 traffic traffic.
Elliott
Elliott Willink
bridge-domain 10
bridge-domain 20
bridge-domain 30
interface BDI10
interface BDI20
interface BDI30
interface Ten0/0/0
        bridge-domain 10
        bridge-domain 20
        bridge-domain 30
interface Ten0/0/1
        bridge-domain 10
        bridge-domain 20
        bridge-domain 30
Elliott
jroy777
So I have a 1001-X and I want to trunk 3 vlans on my Lan interface to a fortinet switch. The scenario above looks like it keeps all vlans segmented across both sides of the ASR which would be great if we had vlans on the wan side of the ASR. It connect via a 10G layer 2 network with no vlans assigned. Doesnt seem like this scenario above would work for that.
