The purpose of EIGRP Split Horizon
Sam-CCNP
Hi anyone,
Quick question, but am I right in assuming that the purpose of Split Horizon in EIGRP is to suppress unnecessary updates rather than to prevent routing loops?
DUAL (and the FC) seems to take care of routing loops, so I'm thinking that is its only point.
Sam
17 Replies 17
MHM
Thanks for replying, although your explanation doesn't make sense.
Could you please clarify the topology of the network you are using in your example and where you think updates are being sent to/from.
Sam
Hi @MHM Cisco World ,
I read your response again and I think the following statement is incorrect:
Now R1 loss connect to this prefix' it will use path toward R2 and R3 for this prefix' even if this path is not correct.
Its incorrect because the update(s) received by R1 from R2 and R3 will fail the Feasibility Check and as a result R1 will have have no Feasible Successor. So R1 will then go active and send out queries.
Sam
MHM
I am a bit confused as to what you are trying to prove in your example. Essentially, what I am asking is "does split horizon in EIGRP prevent routing loops?"
Sam
MHM
I disagree, unless you can provide an explanation that makes sense.
balaji.bandi
Its all depends on the use case -
Split horizon is one of the methods used by distance vector routing protocols to avoid routing loops. The principle is simple – a router will not advertise a route back onto the interface from which it was learned. Split horizon is enabled on interfaces by default.
More explain split horizon and FC here  with example :
https://www.practicalnetworking.net/stand-alone/eigrp-feasibility-condition/
BB
Hi @balaji.bandi ,
Thanks for responding.
Yes, I understand its benefit with regard to distance-vector protocols such as RIP, however, EIGRP uses DUAL for loop avoidance, so I am wondering if split-horizon's purpose in EIGRP's case if efficiency because the reverse-route would fail the FC anyway.
Please correct me if I am wrong or misunderstanding.
Thanks.
Sam
DUAL is the calculation that provides the metric. The Feasibility Condition is the "loop" detection and prevention mechanism.
-David
Hi @David Ruess ,
Thank you for clarifying the distinction.
So EIGRP does not require split horizon to maintain a loop-free network? And the FC check is all that is (ultimately) required- correct?
Sam
After double checking the RFC (almost right). DUAL is used for a loop free topology when a single route exists for the network. It will choose the lowest metric route. While DUAL calculates metrics for all paths the Feasibility Condition is what creates the loop free topology for the feasible sucessors.
Split horizon does not prevent loops in and of itself as there are some topologies (like DMVPN) where it needs to be and is disabled.
Here is an excerpt from the EIGRP RFC:https://datatracker.ietf.org/doc/html/rfc7868
1.  Introduction
   This document describes the Enhanced Interior Gateway Routing
   Protocol (EIGRP), a routing protocol designed and developed by Cisco
   Systems, Inc.  DUAL, the algorithm used to converge the control plane
   to a single set of loop-free paths is based on research conducted at
   SRI International [3].  The Diffusing Update Algorithm (DUAL) is the
   algorithm used to obtain loop freedom at every instant throughout a
   route computation [2].  This allows all routers involved in a
   topology change to synchronize at the same time; the routers not
   affected by topology changes are not involved in the recalculation.
   This document describes the protocol that implements these functions.
Second exceprt:
 Feasibility Condition:
      The Feasibility Condition is a sufficient condition used by a
      router to verify whether a neighboring router provides a loop-free
      path to a destination.
Hope this helps
-David
Sam-CCNP
Hi @David Ruess ,
Okay, thanks, I'll have a read.
No mention of split-horizon in the RFC with regard to loop prevention must mean it serves another purpose (I was guessing it's for efficiency).
Yeah, I'm aware that it needs to be disabled in hub and spoke topologies, because the hub needs to advertise back out of the same interface to spokes.
I also see reverse poison is also used in EIGRP, as per other distance-vector protocols, maybe it is to avoid corrupt updates etc being sent to a neighbour.
Anyhow, thanks again for clarifying.
Sam
The poison reverse is just to advertise an infinite metric of the route learned back out the interface it’s using to reach that route. Not necessarily corrupt but I believe it’s to help with querying. If I receive a poison reverse route from my neighbor then obviously it’s using me to get to that network so I probably don’t need to query it if I lose the route. Although I’d have to lab that scenario.
-David
