Setting Up Factory Default Device Using WebUI for cisco ISR1100-4G
Aria
I tried to write these commands in CLI (using Putty) for cisco ISR1100-4G but it seems like the VLAN command is not recognized.
Aria
Step 1
Ensure that the router is in the factory fresh mode. If the router is not in the factory fresh mode, use the write erase option to erase all the configuration from the router.
Step 2
Ensure that the following basic configuration is available on the device.
ip dhcp excluded-address 192.168.1.1 192.168.1.5
ip dhcp pool WEBUIPool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1
username webui privilege 15 secret cisco
interface Vlan1
ip nat inside
no shutdown
Step 3
Connect the PC to any of the switch port which is the member of VLAN1. By default, all the ports will be the member of VLAN1 and the PC recieves the IP address from the pool WEBUIPool.
Step 4
After your PC receives the IP address, launch the browser, type https://192.168.1.1/webui/#/dayZeroRouting or enter http://192.168.1.1/webui/#/dayZeroRouting.
Step 5
Enter the default username (webui) and default password (cisco).
7 Replies 7
DanielP211
Hello!
Do the other commands work? I don't think the ISR1100-4G supports switchports it only has routed ports if I'm not mistaken. So try setting the IP directly on the intefrace and connect to it.
BR
****Kindly rate all useful posts*****
Hi. Thanks.
I tried first configure the interface 0 and defined an IP for port 0 but when I connected to the Web interface then the menu showing was incomplete. As I only saw Monitoring and Dashboard menu and other menu were hidden.
Do you have any suggestions?
Aria
balaji.bandi
i think we had long discussion on other thread you posted.
After Factory reset - can you post show version and dir  (output here)
is the device installed bundle or install mode (i also suggest to convert this to install mode and test it)
BB
Hi. Here are the outputs of commands:
Router#show version
Cisco IOS XE Software, Version 17.12.03
Cisco IOS Software [Dublin], isr1100be Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.12.3, RELEASE SOFTWARE (fc7)
Copyright (c) 1986-2024 by Cisco Systems, Inc.
Compiled Wed 20-Mar-24 15:50 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2024 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 17.7(1r)
Router uptime is 22 hours, 50 minutes
Uptime for this control processor is 22 hours, 51 minutes
System returned to ROM by PowerOn
System image file is "usb0:isr1100be-universalk9.17.12.03.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Controller-managed
The current throughput level is unthrottled
Smart Licensing Status: Smart Licensing Using Policy
cisco ISR1100-4G (1RU) processor with 1310911K/6147K bytes of memory.
Processor board ID FGL2746L99Y
Router operating mode: Controller-Managed
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
5949439K bytes of flash memory at bootflash:.
Configuration register is 0x8000
And dir command:
Router#dir
Directory of bootflash:/
283361 drwx 4096 May 4 2024 01:55:39 +00:00 tracelogs
12 -rwx 749 May 3 2024 13:22:01 +00:00 mode_event_log
89057 drwx 4096 May 3 2024 13:21:54 +00:00 sdwan
307651 -rw- 9399 May 3 2024 13:21:10 +00:00 packages.conf
307671 -rw- 40199538 May 3 2024 13:20:34 +00:00 isr1100be-rpboot.17.12.03.SPA.pkg
307670 -rw- 695967744 May 3 2024 13:19:42 +00:00 isr1100be-mono-universalk9.17.12.03.SPA.pkg
307669 -rw- 167936 May 3 2024 13:19:38 +00:00 isr1100be-firmware_sm_nim_adpt.17.12.03.SPA.pkg
307668 -rw- 2138112 May 3 2024 13:19:38 +00:00 isr1100be-firmware_sm_dsp_sp2700.17.12.03.SPA.pkg
307667 -rw- 14557184 May 3 2024 13:19:38 +00:00 isr1100be-firmware_sm_async.17.12.03.SPA.pkg
307666 -rw- 11366400 May 3 2024 13:19:37 +00:00 isr1100be-firmware_sm_1t3e3.17.12.03.SPA.pkg
307665 -rw- 2527232 May 3 2024 13:19:37 +00:00 isr1100be-firmware_sm_10g.17.12.03.SPA.pkg
307664 -rw- 10432512 May 3 2024 13:19:37 +00:00 isr1100be-firmware_prince.17.12.03.SPA.pkg
307663 -rw- 5677056 May 3 2024 13:19:37 +00:00 isr1100be-firmware_nim_xdsl.17.12.03.SPA.pkg
307662 -rw- 5431296 May 3 2024 13:19:37 +00:00 isr1100be-firmware_nim_ssd.17.12.03.SPA.pkg
307661 -rw- 11763712 May 3 2024 13:19:37 +00:00 isr1100be-firmware_nim_shdsl.17.12.03.SPA.pkg
307660 -rw- 2994176 May 3 2024 13:19:37 +00:00 isr1100be-firmware_nim_ge.17.12.03.SPA.pkg
307659 -rw- 17973248 May 3 2024 13:19:37 +00:00 isr1100be-firmware_nim_cwan.17.12.03.SPA.pkg
307658 -rw- 4894720 May 3 2024 13:19:37 +00:00 isr1100be-firmware_nim_bri_st_fw.17.12.03.SPA.pkg
307657 -rw- 13144064 May 3 2024 13:19:37 +00:00 isr1100be-firmware_nim_async.17.12.03.SPA.pkg
307656 -rw- 11501568 May 3 2024 13:19:37 +00:00 isr1100be-firmware_ngwic_t1e1.17.12.03.SPA.pkg
307655 -rw- 18657280 May 3 2024 13:19:37 +00:00 isr1100be-firmware_dsp_tilegx.17.12.03.SPA.pkg
307654 -rw- 2007040 May 3 2024 13:19:37 +00:00 isr1100be-firmware_dsp_sp2700.17.12.03.SPA.pkg
307653 -rw- 6799360 May 3 2024 13:19:37 +00:00 isr1100be-firmware_dsp_analogbri.17.12.03.SPA.pkg
307652 -rw- 65536 May 3 2024 13:19:37 +00:00 isr1100be-firmware_dreamliner.17.12.03.SPA.pkg
23 -rw- 9399 May 3 2024 13:19:33 +00:00 prev_packages.conf
21 -rw- 106 May 3 2024 13:18:30 +00:00 pki_certificates
48577 drwx 4096 May 3 2024 13:17:59 +00:00 license_evlog
19 -rw- 30 May 3 2024 13:16:27 +00:00 throughput_monitor_params
16 -rw- 137995 May 3 2024 13:16:16 +00:00 memleak.tcl
13 -rw- 394 May 3 2024 13:15:21 +00:00 poweron_debug.txt
22 -rw- 2571280 May 3 2024 12:21:27 +00:00 C1100-rommon-1612-1r-SPA.pkg
24290 drwx 4096 May 3 2024 12:15:48 +00:00 dbgd
20 -rw- 145 May 3 2024 12:15:24 +00:00 topnmemuse
145729 drwx 4096 May 3 2024 12:15:22 +00:00 .prst_sync
64769 drwx 4096 May 3 2024 12:14:11 +00:00 pnp-tech
129537 drwx 4096 May 3 2024 12:10:52 +00:00 core
56673 drwx 4096 May 3 2024 12:10:49 +00:00 pnp-info
32385 drwx 4096 May 3 2024 12:09:17 +00:00 onep
348129 drwx 4096 May 3 2024 12:09:14 +00:00 .geo
331937 drwx 4096 May 3 2024 12:09:10 +00:00 vmanage-admin
291457 drwx 4096 May 3 2024 12:09:08 +00:00 .sdwaninternal
234785 drwx 4096 May 3 2024 12:08:59 +00:00 .dbpersist
18 -rw- 1923 May 3 2024 12:08:53 +00:00 trustidrootx3_ca_092024.ca
17 -rw- 20109 May 3 2024 12:08:53 +00:00 ios_core.p7b
8097 drwx 4096 May 3 2024 12:08:23 +00:00 .ssh
105249 drwx 4096 May 3 2024 12:08:17 +00:00 .rollback_timer
178113 drwx 4096 May 3 2024 12:08:05 +00:00 sysboot
259073 drwx 4096 May 3 2024 12:07:55 +00:00 pcap
356225 drwx 4096 May 3 2024 12:07:55 +00:00 SHARED-IOX
11 drwx 16384 May 3 2024 12:07:52 +00:00 lost+found
6044110848 bytes total (3596029952 bytes free)
I also tried the line vty 0 4 and line vty 0 30 but it didn't help.
I called the licensing team at Cisco they told me PNP licenses is not registered with the device. Do you think that's the cause of the problem of not showing web interface completely?
Aria
In CLI, I get this error:
Router(config)# interface Vlan1 Router(config-Vlan-1)# ip address 192.168.1.1 255.255.255.0 Router(config-Vlan-1)# ip nat inside Router(config-Vlan-1)# no shutdown Router(config-Vlan-1)# exit Router(config)# exit Uncommitted changes found, commit them? [yes/no/CANCEL] yes Aborted: inconsistent value: Device refused one or more commands: interface Vlan1 ^ % Invalid input detected at '^' marker." Error executing command: CLI command error -
Does anyone have any idea how to fix this?
Basically I plan to connect to the Web interface of Cisco router ISR1100 but the Web interface is shown as incomplete as I only have Navigation and Dashboard menu.
Aria
can you also post below output :
show run | in boot
show platform software device-mode
show run
As i have mentioned before you have bizzare config reg
Configuration register is 0x8000   <-- change this to right config reg as mentioned below document.
https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/50421-config-register-use.html
to access the device, not required License. i am not sure you running SD-WAN controller mode (so post above asked command to see is the devices in controller mode and normal mode)
BB
Hi.
There are the commands:
Router#show run | in boot
boot-start-marker
boot-end-marker
diagnostic bootup level minimal
Router#show platform
Chassis type: ISR1100-4G
Slot Type State Insert time (ago)
0 ISR1100-4G ok 3d04h
0/0 4x1G ok 3d04h
R0 ISR1100-4G ok, active 3d04h
F0 ISR1100-4G ok, active 3d04h
Slot CPLD Version Firmware Version
0 20122333 17.7(1r)
R0 20122333 17.7(1r)
F0 20122333 17.7(1r)
Router#show run
Building configuration...
Current configuration : 2746 bytes
! Last configuration change at 13:22:05 UTC Fri May 3 2024 by IOSP_CLIENT_DMI
version 17.12
service password-encryption
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition 65528
description Internal VRF
address-family ipv4
exit-address-family
vrf definition 65529
description Speedtest VRF
address-family ipv4
exit-address-family
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
aaa authorization console
aaa authorization exec default local
aaa session-id common
no ip dhcp use class
login on-success log
fhrp version vrrp v3
ipv6 unicast-routing
ipv6 rip vrf-mode enable
subscriber templating
vtp version 1
crypto pki trustpoint TP-self-signed-303572524
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-303572524
revocation-check none
rsakeypair TP-self-signed-303572524
hash sha256
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
hash sha256
crypto pki certificate chain TP-self-signed-303572524
crypto pki certificate chain SLA-TrustPoint
license udi pid ISR1100-4G sn FGL2746L99Y
license accept end user agreement
memory free low-watermark processor 61459
username admin privilege 15 secret 9 $9$5lwq/tO/V5q8y.$3eDkKAW0saKIbca2P7nSt4uHI1U/E5A/stv/gF3fB3.
redundancy
mode none
no crypto ikev2 diagnose error
interface Loopback65528
vrf forwarding 65528
ip address 192.168.1.1 255.255.255.255
interface Loopback65529
vrf forwarding 65529
no ip address
interface GigabitEthernet0/0/0
no ip address
negotiation auto
interface GigabitEthernet0/0/1
no ip address
negotiation auto
interface GigabitEthernet0/0/2
no ip address
negotiation auto
interface GigabitEthernet0/0/3
no ip address
negotiation auto
ip forward-protocol nd
no ip http server
ip http secure-server
ip nat settings central-policy
ip nat settings gatekeeper-size 1024
ip nat route vrf 65528 0.0.0.0 0.0.0.0 global
no ip nat service all-algs
no ip ssh bulk-mode
ip scp server enable
control-plane
line con 0
stopbits 1
line aux 0
line vty 0 4
transport input none
line vty 5 80
no network-clock revertive
telemetry receiver protocol confd-rfc5277
host ip-address 0.0.0.0 0
protocol rfc5277
netconf-yang
netconf-yang feature candidate-datastore
end
Aria
