DS3 bandwidth
wilson_1234_2
Level 3
Level 3
I have a 7206 router and I am trying to determine the correct DS3 banwidth from the serial interface .
The configuration of the interface is as shown:
interface Serial1/0
no ip address
encapsulation frame-relay IETF
ip route-cache flow
load-interval 30
dsu bandwidth 44210
framing c-bit
cablelength 50
clock source internal
serial restart-delay 0
frame-relay lmi-type ansi
frame-relay intf-type dce
There are subinterfaces configured below that, but the DS3 is a point to point to our DR side.
The interface is only going to show what is configured under the Bandwidth statement corrrect?
Is there any way to determine if we are getting 45Mbps bandwidth from the interface?
paolo bevilacqua
Yes, you are. The only thing that would change bandwidth is the "dsu bandwidth" statement.
The what kind of bandwidth you have via Frame-relay, it's another issue.
hope this helps, please rate post if it does!
