DSL troubleshooting
boblutton
I'm trying to connect a Zoom DSL modem to 7200 router.
Debugging from 7200 shows that when the Zoom tries to connect, it succeeds. It's link lights show connected. Surfing is good, and consistant.
But,while connected,and while surfing, more debugging shows line protocol going up and down all the time on the "virtual-access" interface
Does this mean that the line protocol for the virtual interface (up or down) has nothing to do with whether the connection is up ?
Any suggestions or good links for troubleshooting DSL ?
6 Replies 6
thisisshanky
Level 11
Level 11
I assume, you are using 7200's FE to do PPPOE/OA ? Could you paste your configs ? Virtual access interface comes up after PPPOE negotiations completes and it gets an ip address leased.
You could use debugs such as
debug vpdn pppoe-events
show vpdn
debug pppoe-errors
debug pppoe-packets
PPP layer troubleshooting can be done with
debug ppp auth
debug ppp neg
PS: please remember to rate helpful posts!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
To add note iam attaching the following URL which will give you info on the troubleshooting.
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1834/products_feature_guide09186a00800800f4.html
Cheers
Rate it if useful
the link you provided for the troubleshooting guide does not work, do you have a valid link?
Colin
Is the virtual-access on layer 2 or 3.
I've tried debugs for ppp authentication, negotiation and errors, but can't see anything conclusive
i'm using the atm interface
modems are configured with pppoa and llc
here are some key config statements from the 7200
interface ATM2/0.1 multipoint
class-int res-b
range Res pvc 1/100 1/500
class-range Res-B
ubr 1536
encapsulation aal5snap
protocol ppp Virtual-Template1
pvc-in-range 1/114
vpdn enable
vpdn-group 1
accept-dialin
protocol pppoe
virtual-template 1
class-int res-b
class-range Res-B
ubr 1536
pvc-in-range 1/114
vpdn enable
vpdn-group 1
accept-dialin
protocol pppoe
virtual-template 1
class-int res-b
class-range Res-B
ubr 1536
pvc-in-range 1/114
vpdn enable
vpdn-group 1
accept-dialin
protocol pppoe
virtual-template 1
