DUAL ADSL
iliass joudat
Good evening everyone;
I have a cisco router 1921 with 2 ADSL card, I want to establish dual balance
ISP1: 41.142.142.21,
ISP2: 41.142.142.22
G0 / 0 192.168.3.1
thank you
16 Replies 16
Francis Garcia
It would be good that you add more details about your implementation, I mean, is the dual balance is incoming or outgoing?
hi ; Francis ;
this for outgoing application
tanks
Hi Paolo ,
i can't acces to your link
just strip the partner string in the link.
Regards.
Alain
There is no partner in the link. It is accessible to anyone.
Hi Paolo,
correct but when i highlighted the link it was appearing, i should have tried to open it instead.
Regards.
Alain
You are right, I've fixed it now, thanks.
can you tack a look to my config please ?
Francis Garcia
I think that the link that Paolo sent was what you were looking for. It has the proper configuration for outgoing loadbalance.
iliass joudat
Hi ,
tinks for your support and i did same ting but, that not working ,
this is my config :
Building configuration...
Current configuration : 5247 bytes
! Last configuration change at 19:12:05 UTC Thu Oct 4 2012 by itsmaroc
! NVRAM config last updated at 19:09:45 UTC Thu Oct 4 2012
version 15.1
hostname *******
boot-start-marker
boot-end-marker
no logging buffered
no logging console
enable password *******
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.3.1
ip dhcp excluded-address 192.168.3.11 192.168.3.254
ip dhcp pool FIRE
import all
network 192.168.3.0 255.255.255.0
dns-server 212.217.0.1 212.217.1.1
default-router 192.168.3.1
ip name-server 212.217.0.1
ip name-server 212.217.1.1
crypto pki trustpoint TP-self-signed-1280271872
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1280271872
revocation-check none
rsakeypair TP-self-signed-1280271872
crypto pki certificate chain TP-self-signed-1280271872
certificate self-signed 01
      quit
license udi pid CISCO1921/K9 sn FCZ16199053
license boot module c1900 technology-package securityk9
username ******* privilege 15 password 0 *******
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.3.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1412
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.2 point-to-point
pvc 8/35
  pppoe-client dial-pool-number 1
interface ATM0/1/0
no ip address
interface ATM0/1/0.1 point-to-point
pvc 8/35
  oam-pvc manage
  pppoe-client dial-pool-number 2
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname *******
ppp chap password 0 *******
ppp pap sent-username ******* password 0 *******
interface Dialer2
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.3.35 443 interface Dialer1 443
ip nat inside source static tcp 192.168.3.39 8080 interface Dialer1 8080
ip nat inside source static tcp 192.168.3.43 80 interface Dialer1 80
ip nat inside source static tcp 192.168.3.47 90 interface Dialer1 90
ip nat inside source static tcp 192.168.3.47 22 interface Dialer1 22
ip nat inside source route-map fixed-nat interface Dialer1 overload
ip nat inside source route-map fixed-nat2 interface Dialer2 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 track 123
access-list 1 remark INSIDE_IF=GigabitEthernet0/0
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 110 permit ip 192.168.3.0 0.0.0.255 any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map fixed-nat2 permit 10
match ip address 110
match interface Dialer2
route-map fixed-nat permit 10
match interface Dialer1
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
password itsmaroc
login
transport input telnet ssh
scheduler allocate 20000 1000
end
Aparently you are missing two configurations, number 1: a default route using Dialer 2 and number 2: you are defining the static route using the Dialer 1 with a track statement which doesn't exist. I recomend you, for the sake of the simplicity, that you define only the defaults routes without using SLA "track command" until you understand the concept of SLA.
Only apply this to your configuration and dont forget to erase the default old route
no ip route 0.0.0.0 0.0.0.0 Dialer 1 track 123
Ip route 0.0.0.0 0.0.0.0 Dialer 2
Hi ,
its work now , but i have to more problems ,
  1. if  i turn of the first ISP cable (dialer 1 ), the balance don't work  correctly , but if i turn off the second ISP cable ( dialer 2) , its  works
  2. normally i have 20 mb/s per ISP , and now , the  performance of browsing is very slow ,  , i think they are some ting  wrong with filtering
  3. the NAT for SMTP and Web servers dont work any more
thinks for you support again
this is my last config :
Current configuration : 5258 bytes
! Last configuration change at 17:44:02 UTC Sun Oct 7 2012 by itsmaroc
! NVRAM config last updated at 10:35:19 UTC Fri Oct 5 2012
version 15.1
hostname ROUTER
boot-start-marker
boot-end-marker
no logging buffered
no logging console
enable password test
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool FIRE
import all
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31323830 32373138 3732301E 170D3132 31303033 32323439
  34385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
username test privilege 15 password 0 test
no ip address
shutdown
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
pvc 8/35
interface ATM0/1/0
no ip address
pvc 8/35
  oam-pvc manage
interface Dialer1
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname test
ppp chap password 0 test
ppp pap sent-username test password 0 test
interface Dialer2
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
ip http server
ip route 0.0.0.0 0.0.0.0 Dialer2
control-plane
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
privilege level 15
password test
login
end
to add to paolo's reply, could you also get rid of this:
Regards.
Alain
