EIGRP Flap on DS3 link , no drop on WAN
gajanangavli
I have configured new DS3 link as below.Also GRE tunnel build on it.EIGRP running between tunnel interfaces.
EIGRP is flapping every minute , i dont found any packet drop between 2 routers WAN interfaces, but ping stcuks for some time.
During this time EIGRP flaps.ISP dont found any issue in network.
int s4/0
ip add x.x.x.x
encapsulation ppp
dsu bandwidth 44210
scramble
crc 32
serial restart-delay 0
interface Tunnel155
  bandwidth 25000
ip address A.B.C.D
no ip redirects
no ip proxy-arp
ip tcp adjust-mss 1432
load-interval 30
delay 100
qos pre-classify
keepalive 10 3
tunnel source Serial4/0
tunnel destination YY.Y.Y.
Did you check the IP MTU on both sides of the tunnel? You might want to reduce the MTU size according to how much your physical link supports.
5 Replies 5
Raju Sekharan
Can you paste the logs you are getting
and paste the ping results
HI,
Logs are as below.
%DUAL-5-NBRCHANGE: EIGRP-IPv4 888: Neighbor X.X.X.X (Tunnel155) is down: retry limit exceeded
%DUAL-5-NBRCHANGE: EIGRP-IPv4 888: Neighbor X.X.X.X (Tunnel155) is up: new adjacency
Ping response dont have any drop , but when ping observed closely , ping stucks at some point & eigrp flaps at that point.ping completes without drop.
What is the logs on other end
and interface configs
check the ping with the configured MTU with df-bit set and see if you are seeing any drops
Hi Subramaniya/Raj,
After changing the MTU on tunnel interface , this issue got resolved.
Thanks For your help
