Dual WAN for Inside Server by Static NAT and PBR.
tanveer2005
Please see the attached to understend. (tanh123@hotmail.com)
My goel is to access inside Server from outside with two public IP from 2 ISPs at same time. by static NST or PBR.
Please help me.
I can Ping to webserver by both public ips at same time ,but i can browes by using only
first default route bublic IP from outside internet. Can some one solved my problem or any change
required.
This is runn conf.
interface FastEthernet0/0.1
encapsulation dot1Q 9-----------LAN
ip address 10.10.5.70 255.255.255.0
ip nat inside
interface FastEthernet0/0.3
encapsulation dot1Q 3---------- ISP-1
ip address 82.128.161.50 255.255.255.224
ip nat outside
interface FastEthernet0/0.4
encapsulation dot1Q 4--------------ISP-2
ip address 77.192.187.250 255.255.255.248
ip nat outside
ip nat inside source static 10.10.5.60 82.128.161.51 route-map isp1
ip nat inside source static 10.10.5.60 77.192.187.251 route-map isp2
ip classless
ip route 0.0.0.0 0.0.0.0 77.192.187.254
ip route 0.0.0.0 0.0.0.0 82.128.161.33 20
no ip http server
route-map isp2 permit 10
match interface FastEthernet0/0.4
route-map isp1 permit 10
match interface FastEthernet0/0.3
9 Accepted Solutions
Fabrice Ducomble
There is no very real 'clean' solution for this.
One way to make this working is to force NAT to happen before the forwarding decision and then forward the traffic based on translated IP.
This is achieved by using PBR on the inside interface in order to forward packet back from the internal server towards a loopback interface defined as 'ip nat outside'. This triggers NAT and then PBR defined on loopback forward traffic towards right ISP based on source IP.
Here below a sample config to achieve this :
interface Loopback100
description Used for static NAT services
ip address 192.168.1.1 255.255.255.252
ip nat outside
ip policy route-map PBR-LOOP
ip nat inside
ip policy route-map PBR-LAN
route-map PBR-LAN permit 10
match ip address STATIC-NAT-SERVICES
set ip next-hop 192.168.1.2
ip access-list extended STATIC-NAT-SERVICES
permit ip host 10.10.5.60 any
route-map PBR-LOOP permit 10
match ip address STATIC-NAT-ISP1
set ip next-hop 82.128.161.33
route-map PBR-LOOP permit 20
match ip address STATIC-NAT-ISP2
set ip next-hop 77.192.187.254
ip access-list extended STATIC-NAT-ISP1
permit ip host 82.128.161.51 any
ip access-list extended STATIC-NAT-ISP2
permit ip host 77.192.187.251 any
Let me know if you face problem.
Thx,
Fabrice
Fabrice Ducomble
Hi Tanveer,
ip nat inside source static 10.10.5.60 82.128.161.51 route-map isp1-------- Where is this or we need
ip nat inside source static 10.10.5.60 77.192.187.251 route-map isp2-------Where is this or we need
The route-maps in static NAT command are needed if internal servers potentially initiate some sessions to outside hosts. This to ensure that the correct NAT statement will be used based on the exit interface selected by CEF.
set ip next-hop 192.168.1.2---------- what is this # or it is 1
The .2 could be any IP in the subnet defined on loopback. It should NOT be the address of the loopback (.1)
Thx,
Fabrice
Fabrice Ducomble
ok, you'll need to drop the route-map in static NAT statement.
Basically, it's needed when we use NAT per TCP/UDP port. Then the acl used in PBR is more specific and we bypass PBR for the traffic initiated from the servers.
In your case, all traffic from server hits PBR and the route-map of static NAT should be removed since egress interface is loopback interface when NAT kicks in and not real WAN interfaces...
So just try with same config except that route-map are removed from static NAT.
Thx,
Fabrice
Hi Tanveer,
You need to add 'extendable' keyword at the end of the static NAT
command to use same Inside local address :
ip nat inside source static 10.10.5.60 77.192.187.251 extendable
ip nat inside source static 10.10.5.60 82.128.161.51 extendable
Thx,
Fabrice
Hello Tanveer,
Thanks for feedback. Using a loopback as we did is the only way when the
servers are directly connected to the NAT router.
When there is a NAT capable device (Firewall for ex.) in between the NAT
router and server, we can do an extra NAT operation on that box which
eliminates the need for the loopback on NAT router.
Thx,
Fabrice
Could someone explain why are we using this ACL.. If the traffic is generated from one of these devices its fine.. What if traffic is sourced from some public IP.
These acl are used with PBR done on the loopback interface. The goal is to match packets back from internal server after the NAT translation, so we can forward the packet to the right ISP, depending on source IP (inside global addresses).
Thx,
Fabrice
Whole problem comes from the fact vast majority of ISPs are doing uRPF check so
that's why we need to ensuree the return packets are sent through same provider it came in.
Thx,
Fabrice
Great thx. I have problem in understanding how uRPF works. I will create a another thread for that. Thanks again for all your great effort.
26 Replies 26
Fabrice Ducomble
ip nat outside
ip nat inside
Thx,
Fabrice
Dear Mr.Fabric,
Please Thank you very much, but just cleare some things as highlights in red color.
ip nat outside
ip nat inside
Hello Fabrice
Awesome solution. But can you please explain what exactly happened with the orginal configuration and what was causing the web page to be not working for a particular IP.
My understanding is below and please tell me what happened next.
Traffic coming fom the internet first hits the below NAT entry and entered the server, and the server is responding with its own private IP as sourc and orginal source IP as the destination.
Now the packet hits the Fa0/0.1 and translating the private IP back to the public IP using the existing NAT entry in the table and sending out the traffic to the more preffered route with AD of 1. So are you trying to say that all the traffic uses the more preffered ISP path(77.192.187.254), even through orginally the packet received on different ISP side.
Please advice exactly what happened, Also tell me the order of NAT operation if possible.
Kasi
-> when packet is received on inside interface, we first do the routing decision and then (assuming the egress interface is configured as NAT outside) we do the NAT translation. So when the forwarding decision is made, we don't know which ISPF the packet came from. That's why we need this trick with the loopback to force NAT operation before the forwarding decision.
I hope this helps,
Fabrice
Fabrice,
-> when packet is received on inside interface, we first do the  routing decision and then (assuming the egress interface is configured  as NAT outside) we do the NAT translation. So when the forwarding  decision is made, we don't know which ISPF the packet came from ---> Ok consider in that situation we are sending the packet to the more preffered ISP based on the routing table. Do you think Async path might be the issue or ISP is dropping the packet, because of not having their own allocated source IP.
Thx,
Fabrice
Fabrice Ducomble
Hi Tanveer,
Thx,
Fabrice
Thanks, it is working but one problem with it , from server i can not reached to out side (no internet) , also i can not ping the server from out side. but i can browse the server from out side with any public IP.
This is my runn  config.
enable secret 5 $1$HS08$ibuEtGDSO7r7m3FH.d0bgjOZ/
enable password 7 1218011A1Bb055H0C2527203213D32
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
interface Loopback0
ip address 192.168.150.1 255.255.255.252
ip nat outside
interface ATM0/0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
ip address 10.10.1.9 255.255.255.0
speed auto
full-duplex
ip nat inside
ip nat outside
ip nat outside
ip classless
ip route 0.0.0.0 0.0.0.0 77.192.187.254 10
no ip http server
set ip next-hop 192.168.150.2
set ip next-hop 82.118.161.33
set ip next-hop 77.92.187.254
snmp-server community public RO
snmp-server enable traps tty
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
password 7 1416160GH6050A7E232B24373C2CF1A453
login
end
Router#
Hello Fabrice,
This is really really neat solution! I like it very much!
Now i am trying to achieve exactly the same thing and i am using your approach, but for some reason it's not working for me.. I understand very well the idea behing it and i am struggling to understand why is it failing for me.
here's my config:
LAN interface:
interface Vlan648
description LAN
ip address 10.10.148.2 255.255.255.0
ip nat inside
ip virtual-reassembly in
standby 1 ip 10.10.148.1
standby 1 priority 10
standby 1 preempt
ip policy route-map rmap_pbr_lan
end
ISP1 interface:
interface Vlan802
description ISP1
bandwidth 4000
ip address 1.2.3.121 255.255.255.252 secondary
ip address 1.2.3.198 255.255.255.252
ip nat outside
load-interval 30
crypto map vpnmap_1
ISP2 interface:
interface Vlan605
description ISP2
bandwidth 4000
ip address 5.6.7.129 255.255.255.224
ip nat outside
load-interval 30
Loopback interface:
interface Loopback1
ip address 10.10.224.1 255.255.255.252
ip nat outside
ip policy route-map rmap_pbr_loopback
route-maps & ACLs:
ip access-list extended acl_nat_internet
deny   ip host 10.10.1.12 any
deny   ip any 10.0.0.0 0.255.255.255
deny   ip any 172.16.0.0 0.15.255.255
deny   ip any 192.168.0.0 0.0.255.255
permit ip 10.10.0.0 0.0.255.255 any
permit ip 10.100.0.0 0.0.255.255 any
ip access-list extended acl_pbr_lan_staticnathosts
permit ip host 10.10.148.10 any
permit ip host 10.10.1.13 any
permit ip host 10.10.1.16 any
permit ip host 10.10.1.100 any
permit ip host 10.10.1.12 any
ip access-list extended acl_pbr_isp_ispa
permit ip host 5.6.7.129 any
ip access-list extended acl_pbr_isp_mtn
permit ip host 1.2.3.121 any
permit ip host 1.2.3.198 any
route-map rmap_pbr_lan permit 10
match ip address acl_pbr_lan_staticnathosts
set ip next-hop 10.10.224.2
route-map rmap_nat_internet_ispa permit 10
match ip address acl_nat_internet
match interface Vlan605
route-map rmap_nat_internet permit 10
match interface Vlan802
route-map rmap_pbr_loopback permit 10
match ip address acl_pbr_isp_mtn
set ip next-hop 1.2.3.197
route-map rmap_pbr_loopback permit 20
match ip address acl_pbr_isp_ispa
set ip next-hop 5.6.7.158
ip nat pool inet-pool 1.2.3.198 1.2.3.198 netmask 255.255.255.252
ip nat inside source route-map rmap_nat_internet pool inet-pool overload
ip nat inside source route-map rmap_nat_internet_ispa interface Vlan605 overload
ip nat inside source static tcp 10.10.1.12 443 1.2.3.121 443 extendable
ip nat inside source static tcp 10.10.1.12 3092 1.2.3.121 3092 extendable
ip nat inside source static tcp 10.10.1.12 443 5.6.7.129 443 extendable
ip nat inside source static tcp 10.10.1.12 3092 5.6.7.129 3092 extendable
Static routes:
ip route 0.0.0.0 0.0.0.0 1.2.3.197 track 4
ip route 0.0.0.0 0.0.0.0 5.6.7.158 10
What happens is when i apply the route-map on the LAN interface i see matches.
But no matches on the route-map on the loopback interface
I see the translations in show ip nat translations as they should be.
InternetRTR1#sh ip nat translations | i 10.10.1.12
tcp 5.6.7.129:443   10.10.1.12:443        78.130.143.36:1329    78.130.143.36:1329
tcp 5.6.7.129:443   10.10.1.12:443        78.130.143.36:5548    78.130.143.36:5548
tcp 5.6.7.129:443   10.10.1.12:443        78.130.143.36:35791   78.130.143.36:35791
tcp 5.6.7.129:443   10.10.1.12:443        78.130.143.36:53634   78.130.143.36:53634
tcp 1.2.3.121:443     10.10.1.12:443        78.130.143.36:50799   78.130.143.36:50799
tcp 1.2.3.121:443     10.10.1.12:443        78.130.143.36:16218   78.130.143.36:16218
InternetRTR1#sh route-map rmap_pbr_lan
route-map rmap_pbr_lan, permit, sequence 10
  Match clauses:
    ip address (access-lists): acl_pbr_lan_staticnathosts
  Set clauses:
  Policy routing matches: 2749 packets, 419906 bytes
InternetRTR1#sh route-map rmap_pbr_loopback
route-map rmap_pbr_loopback, permit, sequence 10
  Match clauses:
    ip address (access-lists): acl_pbr_isp_mtn
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
route-map rmap_pbr_loopback, permit, sequence 20
  Match clauses:
    ip address (access-lists): acl_pbr_isp_ispa
  Set clauses:
Please Help!
Fabrice Ducomble
Thx,
Fabrice
Dear Fabric,
It is giving netting error with the same IP.
NAT already exict with 10.10.5.60 82.128.161.51
ip nat inside source static 10.10.5.60 77.192.187.251------------------ Error when I enter this command.
I Try with two IPs, (Assing two ips to Server.) it is working but not with sing IP, Please see It.
ip nat inside source static 10.10.5.61 77.192.187.251
Thnak you.
tanveer2005
It is working Fine, but you need two IP for LAN , If some one have other solution for only ony IP for LAN server , please Explain.
Router#sh runn
Building configuration...
Current configuration : 1937 bytes
version 12.3
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$HS45408$iutGDSO7r73434mFH.d0bgjOZ/
enable password 7 1218011A135B05580C252720245413D32
no mmi pvc
no aaa new-model
ip subnet-zero
ip cef
interface Loopback0
ip nat outside
interface ATM0/0
no ip address
shutdown
no ip address
speed auto
full-duplex
encapsulation dot1Q 9---------------------LAN
ip nat inside
interface FastEthernet0/0.3 -------------- ISP1
ip nat outside
interface FastEthernet0/0.4-------------- ISP2
ip nat outside
ip nat inside source static 10.10.5.61 82.128.161.51
ip classless
no ip http server
permit ip host 10.10.5.60 any----------------- SERVER LAN IP 1
permit ip host 10.10.5.61 any------------------SERVER LNA IP 2
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
password 7 14161606050A7E232B24GFY34JHF373C2C1453
login
end
Router#
