DVTI over eBGP
imadhassan
I am trying to establish IPSec tunnel between HO and multiple remote sites. I have configured Static tunnel on remote branches and dynamic tunnel on Head Office. The problem is IPSec tunnel is not comming up when I am using BGP as a routing protocol, while running OSPF everything works perfectly. Is there any special configuration steps which need to follow while using BGP?
Hello.
Do you have basic connectivity between the IPSec peers when you are using BGP and when using OSPF?
